New Posts New Posts RSS Feed: Starboard Boat ducking Port Boat question
Post Options Post Options   Quote Rupert Quote  Post ReplyReply Direct Link To This Post Topic: Starboard Boat ducking Port Boat question
    Posted: 10 May 11 at 9:51am
You'll also be in a better position on port to take the lift that you get off the back of a stb boat when ducking if you use Jim's method. Communication is the key here, though - tell the stb boat you have seen her and are ducking, and that will give them the confidence to keep sailing in a straight line, which suits you both.
Garry View Drop Down
Post Options Post Options   Quote Garry Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 11 at 5:42pm
Jim has it spot on, incidentally its also faster.
You can also response with the hail seen you or hold your course to their starboard.  the rules don't require it and they can ignore it if they feel threatened but it might give them confidence that you will avoid them.
Garry
Lark 2252, Contender 298
www.cuckoos.eclipse.co.uk
Andymac View Drop Down
Post Options Post Options   Quote Andymac Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 11 at 4:27pm
I was put in such a situation that Gordon identifies;
Laser open meeting,
I (port) was bearing away to closely duck a Starboard boat, as I did so, the wind veered; even so I was still comfortably in control. Starboard, however was headed by the windshift and tried to execute a tack, In doing so the stern quarter of the Starboard boat turns towards me, to the point where I had insufficient time to make any further adjustments to my trim and steering to avoid a collision. A spontaneous shout from me and Starboard reversed his decision avoiding a collision by millimetres.
We had a friendly chat at lunch about the incident and the other sailor conceded that he had initially changed course in response to the windshift, and not because he thought we were going to collide. Thankfully we just missed each other otherwise he accepted he would have broken 16.2
gordon View Drop Down
Post Options Post Options   Quote gordon Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 10:53am
I would disagree with Brass on one point - I have disqualified boats on more than one occasion because they changed course to windward to initiate a tack causing a port tack boat that was keeping clear to have to take immediate further avoiding action - the problem being that the boat luffing to tack often slows considerably when doing so (more so with keelboats). This would happen in the diagram above if, as Red returned to a close-hauled course (and was keeping clear) Green threw in a tack...
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 8:52am
The thing is you rarely get port/starboard collisions when both boats were sailing along without alteration of course. Almost invariably port has attempted to give way but misjudged it, maybe by starting to turn too late.
If port is attempting to get across starboard's bow then its usually not too bad, because unless port has really misjudged then unless starboard has been brought up in the dodgems school of racing, starboard just has to bear away a bit to clear ports stern, at which point port has to take their penalty. This often leaves port very aggrieved, because they may be convinced that starboard didn't need to duck. Ben Ainslie caught a DSQ in I think the last Olympics in precisely that situation. So if you cross ahead its high risk for Port's race.
The really bad collisions tend to happen when port is attempting to go behind stbd. As you bear away the boat:-
i) accelerates as its now on a reach
ii) quite possibly heels, and the rudder becomes less effective.
the result is that port is now unable to turn fast enough or quick enough, and spears into the side of starboard.
I suspect, without evidence, that most collisions casing significant damage happen in that circumstance.
So if it looks as if port isn't taking enough avoiding action early enough then starboard is going to get very nervous about being T boned.
So what should port do? Fortunately the best thing for port to do to avoid collisions and give Starboard full confidence they won't be hit is also the fastest thing to finish the race. You bear away early, allowing for the speed increase, until you are pointing well behind their stern. You then point back up onto a beat so that as you pass their stern you are already pointing as high as you need, and at full speed or better, yet only need a tiny flick of the tiller if you are a bit too close.
In "right" port is off a collision course very early. In "wrong" port is on a collision course right up to the last second - and thus not keeping clear. Port also ends up two or three boat lengths to leeward of right.
So I guess your coach - and a PC would probably agree - was thinking your course put you closer to wrong than right.
Edited by JimC - 04 May 11 at 8:56am
Brass View Drop Down
Post Options Post Options   Quote Brass Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 5:34am
OK,  please don't think I am trying to give you a hard time:  just trying to encourage you to take an analytical view of the incident and the rules.
In your original post you said that 'as I went to duck they tacked'.  I understand this to mean that S did not change course until you began to bear away, then S changed course towards the wind preparatory to tacking.
If S is changing course towards the wind, and P is bearing away to duck round S, then boats are changing course in opposite directions away from each other.
If S is changing course away from P, how can she be not giving P room to keep clear?
er111a View Drop Down
Post Options Post Options   Quote er111a Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 3:27am
rule 16.1When a right-of-way boat changes course, she shall give the other
boat room to keep clear.
I was thinking of this rule
Post Options Post Options   Quote Brass Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 3:12am
So, your coach thinks that you started your duck too late and/or didn't duck deep enough so that, taking Case 50 into account you didn't keep clear of S and broke rule 10 (and, that being the case, any breach of rule 13 by S in tacking away was compelled by your breach of rule 10 and is to be exonerated under rule 64.1(c)).
You disagree:  apparently you think you ducked deep enough and early enough.
Hopefully, you now understand how Case 50 amplifies how rule 10 applies.
What actually happened is water under the bridge, but you now need to try to learn from the experience.  You could ask your coach what it is that you should have done to make it less likely to have a decision like this go against you in future, and maybe highlight what techniques and drills will help to improve your judgement and execution.
By the way, rule 16.2 is aimed at S hunting P DOWN:  it would be pretty difficult for S to break rule 16.2 by changing course towards the wind.
Post Options Post Options   Quote er111a Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 2:24am
I am part of a highschool sailing team and it was during practice, so there was not a protest committee, but my coach ruled for the boat on S
Post Options Post Options   Quote Brass Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 11 at 2:14am
Originally posted by er111a
1. No
2. Yes
3. Yes
4. Yes
Which of these did the protest committee agree with?
