Help with painting my heron |
doomie22
Topic: Help with painting my heronPosted: 21 Mar 11 at 10:45am |
Hi all,
I am nearly finished removing the paint off my heron, there isn't much to fix on it so I am looking for a guide or help on how to paint the boat again. I am okay with the varnished areas, I am just not understanding all these different paints and tins that are out there. Do I just need to do the following steps? Antifouling - required coats undercoat - required coats top coat - required coats If so, what names of tins am I looking at please? Thank you Doomie
SoggyBadger
Joined: 26 Oct 10 Location: The Wild Wood Online Status: Offline Posts: 552 |
Posted: 21 Mar 11 at 10:55am |
You won't need antifouling. That's only for boats which are kept on moorings.
The first thing you need to do is decide which type of paint you're going to use. Basically you have the choice of "traditional" non-polyurethane, one-pot polyurethane or two-pack polyurethane. Do you know which type was used originally? |
SB |
Posted: 21 Mar 11 at 11:12am |
You don't want antofouling unless it lives on a mooring.
You almost certainly don't want to use two pot on a boat of some age, and definitely not if there is the slightest trace of original paint. So IMHO you should be looking at single pot polyurethane. Blakes and International have some pretty good guides on their websites. I'd always used International, but have been using Blakes recently because International dropped the colour I use from their range and when I had a query I was mightily impressed with Blakes tech support. International (www.yachtpaint.com)you want "Toplac", Blakes (now Hempel www.hempel.com) you want "Brilliant Enamel". The latter uses a combined primer undercoat which would be a saving in the number of tins required. Edited by JimC - 21 Mar 11 at 11:13am |
doomie22
Posted: 21 Mar 11 at 11:36am |
Thank you both, the boat was built in 1963, as for the coats that was on it, it had about 8 coats on it (the person just kept painting over old), i do not know what was used in the past but I know it has an anti fouling coat on it.
The boat will be on its trailer, it will only go in the water when I want to use it. With the "Brilliant Enamel", do you mean that I can just put that straight on with no undercoat? I don't mind getting an undercoat and topcoat as I want to make it look really nice and don't mind the extra work.
Posted: 21 Mar 11 at 12:08pm |
No, its a combined undercoat and primer, so you still need an undercoat, but not a separate primer. I guess I'd probably put on two coats of the undercoat/primer and sand the first one back pretty heavily. Its handy because it means you can sand back heavily for a better finish without worrying about going back to wood on the high spots on the first coat. |
doomie22
Posted: 21 Mar 11 at 12:31pm |
I have picked my top coat colour from blakes/hempel billiant enamel range (going for Rhapsody Blue), I am now just looking at the undercoats/primers of the same comany.
What does everyone recommend on the primer as I have found the boat primer and an epoxy primer? Doomie
SoggyBadger
Posted: 21 Mar 11 at 12:40pm |
SB |
doomie22
Posted: 22 Mar 11 at 12:55pm |
With the Brilliant enamel range, do you do two or more coats or is it just a one coat paint?
Thanks, Neil
kfz
Joined: 02 Nov 10 Location: UK Online Status: Offline Posts: 96 |
Posted: 22 Mar 11 at 1:21pm |
see how it goes. Count on 2. 2 will be better
Kev
tickler
Joined: 03 Jun 07 Location: Tunstead Milton Online Status: Offline Posts: 895 |
Posted: 25 Mar 11 at 7:44pm |
I have painted many boats. I use Hammerite Garage Door paint (smooth) apply it with a brush and roll it off with a short pile mini roller intended for gloss paint.
