Fittings on pro-grip |
charlie1019 ![]() Posting king ![]() Joined: 28 Nov 05 Online Status: Offline Posts: 173 |
![]() ![]() ![]() ![]() Posted: 06 May 10 at 2:06pm |
I'm currious to hear peoples past experience on this one... When a fitting needs to be placed on top of progrip (i.e. like a kite halyard block), can a waterproof seal be gained using the standard sikaflex approach? Or, does the progrip need to be cut away around the fitting to garentee a watertight seal? |
We always used a waterproof bathroom type sealant to seal fittings, we found that when we used sikaflex the fittings leaked and were also a right bugger to replace as they were so well stuck on!
Regardless of the pro-grip, as long as you have plenty of sealant in the hole and on the screw it won't leak. |
You might get a firmer fixing if you don't mount it on a
piece of foam though. |
I guess it depends on the thickness of progrip and if you are screwing or bolting, (although for a kite halyard block I would bolt every time) but the progrip might work like a spring washer and keep it in place.
