Slowing by dragging feet in water |
Page 123 6> |
redback
Joined: 16 Mar 04 Location: Tunbridge Wells Online Status: Offline Posts: 1502 |
Topic: Slowing by dragging feet in waterPosted: 07 Jun 09 at 10:30pm |
I'm sure this is illegal but can't find a reference to a rule which says so. I'd like to be able to quote an appeal or something as I witnessed it today. An 800 was too early at a start and so the crew stuck one foot in the water to slow the boat. I politely mentioned it when ashore but without being able to quote a reference I could not pursue it.
JohnW
Joined: 17 Jul 07 Location: United Kingdom Online Status: Offline Posts: 552 |
Posted: 07 Jun 09 at 10:39pm |
There was a discussion on this last year. Hope this helps. http://www.yachtsandyachting.com/forum/forum_posts.asp?TID=4 585&PN=2&TPN=1 Edited by JohnW |
Smight at BBSC
Joined: 09 Jan 07 Location: Great Britain Online Status: Offline Posts: 1129 |
Posted: 08 Jun 09 at 2:24pm |
I'm pretty sure we established that it wasn't allowed.
RS600 988
Lukepiewalker
Posted: 08 Jun 09 at 6:06pm |
Probably 42.1 covers it.
Ex-Finn GBR533 "Pie Hard"
Andymac
Joined: 04 Apr 07 Location: Derbyshire Online Status: Offline Posts: 852 |
Posted: 08 Jun 09 at 6:26pm |
Indeed, we did. Just to test this principle; i) If boat A clear ahead sailing a steady course, and a faster boat B approached from directly astern 'punted' boat A on the transom. Boat B would be in the wrong, yes? ii) If boat A clear ahead sailing a steady course, with boat B similar speed very close astern, and boat A accidently dropped mainsheet and slowed suddenly with again a rear end shunt. It would, however unfortunate, still be boat B in the wrong, yes? iii) Same scenario as ii) except Boat A slowed suddenly by 'deliberately' trailing leg in water. Boat A broke a rule, boat B exonerated? Would that be correct? |
Lukepiewalker
Posted: 08 Jun 09 at 6:31pm |
Not necessarily in case ii, as boat A could be charged with failing to avoid a collision if it's slowing action were deliberate.
But largely, yes. |
Andymac
Posted: 08 Jun 09 at 9:03pm |
I did state an 'accidental' act in case ii, however in what instance would boat A be at fault if it slowed itself suddenly deliberately, but legitimately, resulting in a rear end shunt? Could it fall under rule 14, avoiding contact? If there was minor contact with no damage then Boat A hasn't broken a rule, or has it? and has boat B? It's the kind of thing that could possibly happen pre-start, or maybe team racing? Rule 16.1 states; When a right-of-way boat changes course, she shall give the other boat room to keep clear. Note I have underlined changes course, it does not mention slowing down or speeding up! Or could a deliberate act to slow resulting in a collision by a following boat fall under rule 2; 'sportsmanship and fair play'? Does anyone know of any cases?
Garry
Posted: 08 Jun 09 at 9:13pm |
I don't know of any cases but you are required (as right of way boat) to give the give way boat the opportunity to keep clear, this applies whether you are altering course or stopping by backing a sail. I thought we'd conclusively established that deliberatly trailing your legs in the water was illegal propulsion (albeit of the negative sort). Garry |
Garry
Garry
Posted: 08 Jun 09 at 9:16pm |
Garry
Lukepiewalker
Posted: 08 Jun 09 at 10:27pm |
Sorry, I misread example ii. If it was an accidental drop of the sheet and the boat merely slowed down then you would reckon the boat astern to have been too close. In case iii, as the leading boat is slowing by breaking 42.1, the boat clear astern isn't expected to allow for the boat clear ahead breaking a rule as in the leg trailing case, but if it were so close that it could not avoid a collision in case of a legal act (ie slowing without backing a sail) they still might be penalised.
I suppose ultimately it's an area of many shades of grey where there are many variables that would subtly alter the ramifications in terms of the positioning and behaviour of the two boats. Edited by Lukepiewalker |
Page 123 6> |
