Gelcoat repairs - tape or no tape ? |
![]() ![]() ![]() ![]() Posted: 07 Jun 09 at 8:04pm |
To cut a long story short, my beloved Laser had an accident and suffered some nasty dings along the gunnel, having dug out any loose gelcoat is seems that there's nothing structural and it looks like a fairly straight forward application of new gelcoat. I have some genuine Laser "Vela Grey" gelcoat - if I tape over the repair to help it keep the shape of the gunnel it will save me a lot of sanding, but will it still harden OK ? ........any recomendations ?
Many thanks in advance, Nigel |
Graduate 2530 'Galaxy' |
Nigel i can confirm that yes it will dry properly, I always tape a gunnel repair as it saves loads of time sanding.
< http-equiv="Content-" content="text/; charset=utf-8">< name="ProgId" content="Word.">< name="Generator" content="M**rosoft Word 12">< name="Originator" content="M**rosoft Word 12">
It depends on the tape. |
Lark 2170
Parcel tape or an overhead projector sheet held down with masking tape tend to work best.
A bit different. I mixed up some epoxy resin and put into a mould which had some making tape around the top. The epoxy reacted with the glue on the tape and made a load of foaming bubbles. In fear of an impending explosion I placed the whole lot in the middle of the garden. To my disappointment it fizzled out and was rather uneventful. The part of the epoxy that reacted with the tape was very weak and brittle. I found this a good way of making a repair to something like the gunwale. Use a mate's undamaged laser to make a mould of the part you damaged. Slap some vaseline on the gunwale and place strips of newpaper on the vaseline (it will stick to it). Then build up by stricking more strips of news paper on with pritt stick. One you have built up to a reasonable thickness remove and place on a radiator for an hour or so. This will make the mould harden off. You then have a near perfect mould for which to place on top of yor repair to get the right shape. You can use this technque to make mould of pretty much anything. I made epoxy mast chocks for the 300. Just remember to criss-cross the paper strips otherwise the mould will not have any strength in it. |
Epoxy certainly needs no air to be able to react- after all, much epoxy moulding is done under vacuum bags.
Al |
I use mylar slot gasket tape with the shiny side applied to the wet gel or epoxy, then held in place with insulating tape. It gives a lovely smooth finish and I have never had a problem with either the gel or epoxy going off. It's also good for trailing edge repairs on foils because if you want to leave a slightly proud edge to then shape back the stiffness of the mylar tape will support the epoxy while it hardens.
Apparently the different resins harden in differnet ways... Epoxy resin uses an oxidising hardner (exposure to the air makes no difference):- Polyester resin (gelcoat) needs to be protected from the air, so I believe it uses a reducing hardner. (i.e. removes oxygen from the monomers). That means that gelcoat put onto uncured epoxy will never set (I can confirm that!), and that either you exclude the air by taping (sellotape is good) over the gelcoat - or you can get gelcoat resin with a wax in it (this forms a skin on the repair and lets the gelcoat harden.) |
If you put MW solution (basically paraffin wax in styrene) in your gelcoat, it is designed to act as an air barrier and allows the gelcoat to go off without tape. However, you won't get the smooth finish, of course. Plastic Padding gelcoat filler (the white stuff) already has this or something similar in to allow it to go off. If you don't have the right colour Laser/RS etc colour, with lots of fiddling you can get pretty close using either small amounts of acrylic paint or powder paint to change the colour. I was surprised that gelcoat still set with acrylic paint in it when I tried a bit from a model set one of the kids had. |
Thanks for your advice, it's most appreciated. I was hoping to do the gel-coat this evening but it's a bit cool - Saturday looks perfect though, warm and dry with not much wind (so I won't feel so bad about not sailing)
Cheers, Nigel |
