Starting in Large/Quality Fleets - Tips |
Page 123 10> |
bustinben ![]() Far too distracted from work ![]() Joined: 15 Oct 06 Online Status: Offline Posts: 288 |
![]() ![]() ![]() ![]() Posted: 24 Feb 09 at 11:59am |
I always seem to struggle on a packed line - and I'm getting fed up with it! I've got speed upwind, downwind, my strategy is decent 70% of the time... But when I come up against a packed starting line I tank. I get a clean start with good speed and room around me only 20% of the time. It's getting me down, as at smaller open meetings I can nail it without any problems, but at big events I just get destroyed! So, I've been trying to come up with ways to improve this - so I made a list of the things that I need to do in order to try and get a good start. I figure if I follow this religiously I'll reduce the number of times I turn a good position into an awful one before the race even begins. Set up:
So that's all the info one should need to get a decent start I reckon. Then onto the sequence of actions:
So, has anyone got anything I should add to these lists? How about general tips to help me avoid getting parked up on the gun? What about any left-field strategies, like reaching down behind the front row rather than parking up and holding? Edited by bustinben |
A lot of this is in the head, stay calm, dont panic, have options if you can and in that last min or so dont be afraid to change things if it doesnt look good. Also if you look unsure others will pick up on this, be confident and dominate the water around you. |
read 'winning in one designs' (can't remember who its by) but anyone racing at all, let alone in a one design fleet, should read this book. Pop down to the dighy sho in a couple of weeks and you'll brobably be able to get a bargin on it too.
FLAT IS FAST!
Shifts Happen |
Ben I often found myself in your position when I first started attending the RS circuit in my 600 even though in smaller open meetings at my home club I'd be fine, and I eventually realised that what I was doing was basically not thinking things through, and just being led through the start by the pack. Once I realised the mistake I set about holding back in the pre-start and looking at the line, the tide, wind and all the other competitors, rather than charging in amongst everyone and worrying about collisions. I would identify my target start position with options, should others go with me and give me dirt. As a result I was able to put the boat into a position where I could maintain clean air off the start. Ok some times I picked the wrong side or had to concede the front row but given the options could always get out in clear air, and found that even when you went the wrong way, typically you would arrive at the first mark ahead of the main pack, typically top 10 out of a 35 boat fleet.
Basically clear air immediately after the start is worth a lot, and getting caught in the main bunch is bad. |
My mistake when first doing big starts was to focus too much on being at the committee boat end of the line. More experienced racers than me would squeeze me so much that it took everything I had to just stay out of their way, let alone hit the line on time at speed. Boats that were mysteriously able to point way hiher than me seemed to luff me to a standstill and I hadn't room in the bunch to tack away without clobbering someone. My solution was to look for less crowded part sof the line. 2/3 of the way between CB and Pin is generally less crowded and gives your boat and head more space. As said, clear air is king at the start. Starting down the line reduces your options for tacking for the port layline but if you have good speed round the course (and a OOD setting a good line) then you should be able to hold your own. Once you have done this a few times and have had good starts at the quieter part of the line you can use that confidence and start working back up to the CB end. Also, what Craig says about foregoing the front row has merits. If the RH side of the course seems to have more wind then settle for starting late but being able to put in an early tack to the better side of the course. Your problem, from what I read Ben (and I assume you sail Laser/Topper from your description of technique) is that perhaps you are focussing too much on the boat and less on the "plan". You need lots of plans. Certainly there is nothing wrong in the technique you describe. |
By Dave Perry I believe, and should be available on Amazon |
You have to be a bit careful about books and their approach to starts, and
given the start is so very important to a good end result, but, it is what it is, the start of the race and you have to work out beforehand what you want to do in the race before you decide where you start. Most of the folk in the line up do as you suggest and get carried along with the fleet, even in the big events where starts can get crowded and sometimes a tad aggressive or appear that way. Now, I'm not an expert at doing this in a dinghy and there's loads I'd like to know like how to stop the damn thing dead in the water when I need to, but in my time I have been an expert at getting the start nailed and in big fleets. And the way you do it is first decide which side of the course you need to go up, it's no good being down the Port end if you need to go right however well favoured the Port end might be for instance. And whatever you do it is fundamental that you get out in the first rank, with your nose at the very least ahead of the guy upwind of you and have his lee bow totally stuffed until he slips behind and away then you foot off and make sure your lee bow doesn't get screwed by the guy in front and to leeward, this is more important in OD fleets. The rest i expect you know, the transits, watch for mid line sag, hunt and peck, favoured ends etc, but never concede the front line, take em over for a restart rather than, watch for tide, never start with the tide on the weather bow, never start at the pin end if there's a wind bend at the other, (like Garda and the cliffs), check who's calling the numbers and watch where he/she's doing it from sometimes you can get away with being well over by being close in to the committee boat under their nose. And if you blow it bang straight over onto the losers tack out the back it's your only hope, never never never sail the first few hundred yards under the pack. There's a simple old adage, stop for 60 secs at the windward mark you might lose half a dozen places, stop for 1 sec at the start you lose 60 places. Edited by G.R.F. |
Your best bet is to try windsurfing for a while; you will then be an expert dinghy sailor on your return
I'd say I am the biggest wimp in large fleets not cos I am pants at starts (probably true) but more protective about hitting other people's boats on the start line/area. Practise makes perfect! |
Page 123 10> |
