New Posts New Posts RSS Feed: Carbon top mast for Laser Radial
Guest View Drop Down
Post Options Post Options   Quote Guest Quote  Post ReplyReply Direct Link To This Post Topic: Carbon top mast for Laser Radial
    Posted: 03 Mar 05 at 6:34pm
Anyone know what is going on, my wife sails a Radial but at 52kgs she is abit light in a breeze and I figure this will be good for her.
Will it use the same sail (I hope so as she's just brought a new one)!!!
Rick
KnightMare View Drop Down
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 05 at 6:46pm
What different properties does that carbon one have?
Spot192 View Drop Down
Post Options Post Options   Quote Spot192 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 05 at 6:56pm
a friend of mine sailed at travemunde and after four races he had to quit, because his carbon top broke. the sail was totally destroyed and of course the top too. donīt know if it was something about his style of sailing (donīt think so to be honest). but you can use the normal sail, as i know.
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 05 at 7:43pm
Oh not too good. Though you do have breakages with the normal masts.
sailor.jon View Drop Down
Post Options Post Options   Quote sailor.jon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 05 at 7:53pm
Allowing expensive options like carbon uppers represents a move away from the laser's trademark one-design concept.
The proposed carbon upper for the radial benifits:
1) More flexible
2) Better strength : weight ratio so less weight up top so less heeling moment.
3) More expensive: the builders can make mega profits by flogging an expensive upper to every radial racer worldwide. (Considering they charge millions for a simple aluminium tube, heaven knows what a carbon spar would cost...)
The lower mast would stay aluminium.
However, as well as all the cost disadvantages, the carbon upper would have another set back for the radial class:
The cost of buying a radial rig would increase from sail + lower to sail + lower + expensive upper. Decreasing the effectiveness of the "formula laser"
Edited by sailor.jon
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 05 at 8:06pm
Good point but it would be a better mast for someone who is overpowered. will alow the top section to fall off slightly, but whether that is worth the costs.......
Post Options Post Options   Quote sailor.jon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 05 at 8:13pm
personally i like the boat as it is, and don't think it needs anymore alterations, tho i do have the XD power packs, tho this made a big differece for me
 i sail at 5feet 9inch / 1.75mts and
weigh 9st 10 / 62kgs
i struggle when the wind gets up, i symaphise with ricks wife
bigwavedave View Drop Down
Post Options Post Options   Quote bigwavedave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 05 at 4:59pm
But will it work? Its no good having sloppy top section if the sail doesn't fit it properly. Downwind in a blow it could be  a bit unpredictable.
Wave Rider View Drop Down
Post Options Post Options   Quote Wave Rider Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 05 at 5:42pm
Also i thought that the point in having the 4.7 rig was that if you became over powered in a radial in a blow, you could switch over to the 4.7 rig  ..............isnt this carbon top mast going to contradict what they were trying to get going?
           -[Franko]-
Chew Valley Lake Sailing Club
           RS600 933
nathan View Drop Down
Post Options Post Options   Quote nathan Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 05 at 8:09pm
The idea was bought in around 2001. 4 masts were lent to RYA laser radial squad members I believe, and these were just used by these sailors... and the matter hasn't officially gone any further (that has been made public anyway). One of those got ran over by a car supposedly, so they should be 3... sounds like Jon Emmett has one. I think that they were made class legal in 2001 and you are allowed to use 'laser supplieded carbon top sections', however laser don't sell carbon top sections at the moment...
