Water at the windward mark |
Pabs ![]() Posting king ![]() Joined: 05 Jan 05 Online Status: Offline Posts: 177 |
![]() ![]() ![]() ![]() Posted: 20 Aug 08 at 12:50pm |
I am a bit confused with this rule is there such thing as water at the windward mark or is it a case of starbourd boat has right of way and i can luff other boats over the mark??
Any advice will do |
Boatless and Clubless
It's really quite simple: If on opposite tacks P keeps clear of S. If on same tacks W keeps clear of L until about to go round the buoy when inside boat has to be given room to round.
PeterV
(Massively wrong, too tired
![]() Edited by Smight at BBSC |
RS600 988
Suggest you read 18.1.b |
I was about to suggest the same thing. |
RS600 988
Spyderman ![]() Newbie ![]() ![]() Joined: 27 Feb 08 Location: Netherlands Online Status: Offline Posts: 39 |
Room at the mark (rule 18) only kicks in when boats are on the same tack at the windward mark.Like PeterV stated at the windward mark S has ROW over P.
If both are on the same tack (whether both on P or S) then rule 18 only has an effect when the keep clear boat is also the inside boat. If the ROW boat is inside boat, rule 18 has no "effect". She stays ROW boat and the other (outside boat) has to keep clear. So the inside boat can continue on close hauled course and take the other to Timboektoe... (there are exceptions under rule 17.1, and rule 18.3, but that is another matter). If the ROW boat is outside boat, only then the keep clear boat has the protection of rule 18.2(a) and must be given room to round the mark. She may not continue. She must round the mark promptly in a seamanlike way in the prevailing conditions. As soon as both boats have passed the mark rule 18 is off again and she then has to keep clear. |
Are you interested in the Racing Rules of Sailing? Go to: http://rrsstudy.blogspot.com
