larger wet and dry paper sheets |
![]() ![]() ![]() ![]() Posted: 13 Feb 08 at 12:07am |
Doing some work on some boat bits - rebuilding a trashed rudder blade while another is built by Stealth marine after a Sprint 15 tried to balance on it. Also painting 2 dagger boards. I'd like to get hold of some W+D in larger sizes than A4 so I can get a good sized sanding block on the job. Anyone have a source? |
I’m sure if you looked around ye web you should be able to find rolls of the stuff. Schools suppliers’ maybe? If not try Screwfix or something like that. |
Ross
Screwfix don't do it; neither does Ebay
Maybe belts for a belt sander?
Ex-Finn GBR533 "Pie Hard"
I'm thinking the WET part of wet and dry would mean you won't find it for a belt sander! I have been searching but can only find the normal sized sheets. Are they not big enough? |
our school glues the A4 sheet down to boards. if you did the same and stuck a handle on the back it would give you an A4 sized sanding block if that helps? |
Landlocked in Africa
I want to make a board / sanding blcok longer than A4. |
You can get dry grit on rolls up to 240 at least - I tend to do large fairing in courser grit on longboards then fine it off with wet on using the little 3m blocks. Try a local car paint wholesaler - they are everywhere...
Simon ... Buy biggest sheets you can, and glue them onto a sheet of paper, and then put THAT on the sanding block?
TandyUK Servers |
excuse ignorance here, but whats the extra sheet of paper for? |
