Sail Numbers |
Hobbo ![]() Far too distracted from work ![]() ![]() Joined: 02 Jun 06 Location: United Kingdom Online Status: Offline Posts: 211 |
![]() ![]() ![]() ![]() Posted: 30 Mar 07 at 4:48pm |
Replacing the numbers on the sail that Contender433 gave me (thanks again Mark
![]() Peeled off the old numbers but there is loads of glue residue - Do i need anything special to get it off or just soap and water? |
Contender GBR 362
Osprey 1318 - IVplay SSC |
An Alcohol based solvent will do it, or Acetone, or Petrol, but there are better people than I who will tell you which will knacker your sail
Crew on 505 8780 |
kasey3000 ![]() Far too distracted from work ![]() ![]() Joined: 06 Apr 04 Location: United Kingdom Online Status: Offline Posts: 401 |
brasso would work without damaging your sail too much....it's what I used on my kestrel when I bought a second hand main....worked really quickly and didn't damage the sail.
49er 908
If in doubt phone a sailmaker....
I think the last time I did such things it was some international paint thinners that was recommended... |
P&B do a special solvent though it's pricey. My guess is that it's really acetone. Once, for the want of anything else, i used Hammerite thinners which ate it no problem and didn't seem to damage the (Dacron) sail. |
scottish_tornad ![]() Groupie ![]() ![]() Joined: 17 Apr 06 Location: Scotland Online Status: Offline Posts: 57 |
Nail polish remover is basically acetone, pinch your mums/girlfriends then its free!
tornado GBR389
www.dalgetybaysc.org/home.htm |
upvc window cleaner --- solvent not cream works a treat , on dacron sail apply it to other side from the number and let it soak through , if lucky number comes off with all the glue , mylar sails peel number and clean up easy.
Cheers guys, will give some of these a bash tomorrow :)
Contender GBR 362
