Fixing holes |
![]() ![]() ![]() ![]() Posted: 27 Sep 06 at 8:54am |
Lots of questions im afraid but in brief we have a finger size hole which is at the centre of a fist sized damaged area in the bottom of a foam sandwich boat. How do we go about repairing it and what materials should we use? Thanks Ian |
http://www.sailingsource.com/cherub/test/doku.php/tech/core_ repair#core_repair Courtesy of the UK Cherubs - just here to help! |
Which boat is that ian
Its a 29er
You may find that the core damage extends wider than the obvious fist sized section. Use a coin to tap around the area of damage and you can tell by the sound if the area is solid or broken |
