Changes at SCHRS |
Page 123 4> |
![]() ![]() ![]() ![]() Posted: 16 Jun 06 at 10:25am |
Hello everyone. Changes are afoot at SCHRS, Richard Allen has resigned as the UK representative as he has too many work commitments now, I'd like to thank Richard for his hard work in the past years.
As a result of Richard's resignation, I was invited to join the SCHRS committee as the UK representative - I have accepted this and I am now getting up-to-speed with this role.
Olivier Bovyn and I are in the process of re-vitalizing the website and more news will be forthcoming soon (as will an e-mail address for me).
But as we do this we want to share some information as to what is happening at present with the SCHRS rating rule.
Currently Jason Smithwick and Olly Harris (both marine architects) are reviewing the rule with a remit to propose changes that will go forward to the ISAF meeting in the Autumn of 2006. One item that is almost certain to be included in the submission to the ISAF is an additional measurement point (and rating) for beam.
We are currently discussing other items such as making the rule easier to administer, easier for measurers to measure boats and also any items within the rule that we feel are outdated (max Spi pole length being one).
The point of this post is to make it public that I have now taken over this role, make it known that SCHRS is evolving (and will continue to do so) and ask you, the sailors that are sailing with the rule (me included) to propose changes to the rule in light of real world experience - we cannot say if these proposals will be included in subsequent submissions to the ISAF, but I will listen and take note of anything that is posted.
I do not want this to becoming a sl*ging session against the SCHRS rule. I want it to be a positive discussion of how the rule can evolve in the future.
Over to you
If you wish to contact me in private, please use the Priveate message function here (for now) as we are still setting up @SCHRS email addresses etc.. I will provide this at a later date.
Jalani ![]() Posting king ![]() ![]() Joined: 03 May 05 Location: Great Britain Online Status: Offline Posts: 164 |
Congratulations?? Simon, I think you may well have your work cut out to make up the ground lost to Texel in recent years. It might be quite a nice addition to publish an additional rating figure per boat or officially sanctioned conversion factor to convert SCHRS to PY. There is often a debate as to the correct PY for a Cat when we come to race all-in against monos. An 'official' figure would at leat have RC and competitor singing off the same hymn sheet. Good luck with the task ahead. |
Far too old to still be doing this......
Stealth F16s "White Rhino" GBR527 & "Yeah Baby" GBR538 |
Congratulations Simon!
Il stay out of attempting to help as my cat knowlage is about as extensive as feva_kids but good luck with your new roll.. |
tornado435 ![]() Posting king ![]() ![]() Joined: 05 May 06 Location: United Kingdom Online Status: Offline Posts: 196 |
Can only second/ third the congratulations. It will be really good to see the rule move and grow in line with the recent changes to CAT sailing. Todays boats are so different to the boats that were around at the time the rule was first proposed. Beam and spinny pole length have always been my two little grumbling points. |
Thanks everyone.
There is not one, the reason being that PY's do not reflect the performance of the boat only (it reflects finishing position in races which by definition is impacted by crew skill) so PY factors in the performance of the sailors. Good example is the Shadow / Inter 17 - Both on SCHRS 107, but the Shadow is 732 and the Inter 735 on PY ! (A very small difference I know). (This might well be the result of a couple of bad regatta's I had - 2 swims in 5 races !) But as an unofficial guide use something lime SCHRS x 6.841 to get PY (I ued the Hurricane 5.9 (1.01 SCHRS vs 691 PY) My schrs email adddress is now set up: SimonL (at) schrs.org Please use this for any SCHRS Communications Thanks
(just change the (at) for the @
Well, just to prove my point If you use the other Multi with a Primary PY (Dart 15) you get 693.9 !!! You see the problem? If SCHRS would agree an 'official' conversion factor then there wouldn't be any arguments..... well, there'd be less I am aware of the differences between the two systems and the inherent problem of what we are trying to do, but then we don't race in an ideal, theoretical world..... |
Indeed. What we have done at Grafham was take schrs and get the ballpark figure, and then adjust the PY (remember this is racing Cats against 1/2 boats) and so the numbers WILL be different, however the 15/18 example does pose a problem ! Consider that 15's and 18's Both are considered under canvassed and so have (perhaps) a more radical PY than other cats as they take even more wind to "get going". We have (most) of the top of the Sprint 15 fleet at Grafham and the only time they have won anywhing on PY was when it was howling (and this was the same event I went for a swim twice) at the last Duke of Edenburgh club Champs. SCHRS is trying to hcap cats against cats, PY tries (and fails IMO) to handicap everything against everything. To convert SCHRS to PY (again IMO) you need to use some sort of calculation as above adn then apply some real world conversion. The difference may also be identified by the fact that D18's do more PY racing (and perform badly) and so have had more returns that have pushed up their PY rating.... Dart 18 SCHRS = 118, X 6.641584 (1.01 / 691) = 807.3 which is different but not by that much. Dart 15 is even more underpowerer !
You cannot get a standard single number conversion between a measurement based system like CHRS and an empirical system like PY. Its logically impossible because the two are working on an entirely different basis.
For example a measurement system will tend to a bias towards well designed craft which are fast for their raw numbers. By contrast an empIrical system runs the risk of favouring unpopular boats that are only sailed by the less talented sailors. I'm sure you can all come up with other examples. none of these biases are "good" or "bad" they're just the nature of the beast... |
Wll said Jim. You have encapsulated far better what I was trying to day. |
Sprint Bob ![]() Far too distracted from work ![]() ![]() Joined: 17 Jan 06 Location: United Kingdom Online Status: Offline Posts: 314 |
Hi Simon, It is a really tough problem. The PY numbers of the Sprint 15 and Dart 18 are in my view correct with respect to one another. By this I mean fair. With respect to monohulls catamarans such as the Sprint 15 & Dart 18 never do well in anything less than a force 4 but do well at higher wind strengths. A handicap system will never address this difference so we have to accept it. The SCHRS system is necessary to accommodate newer classes with a variety of sail plans which will never collect enough empirical data. It is a problem that the formula based SCHRS system does not give similar results for established classes with good PY numbers such as the Dart 18 and Sprint 15. It is even more of a problem when the SCHRS system comes up with different ratings within a class (such as the Sprint 15 & the Sprint 15 Sport mode and probably the Dart 18 unarig single handed mode and the Dart 18 2-up mode). For these reasons the large established classes tend to steer clear of SCHRS rated events in favour of class racing. Any ideas to review the formulea to get the ratio of established classe (Dart 18, Sprint 15, Shearwater & Hobie 16 without spinakker) ratings more similar to the PY numbers would be beneficial in my view. What ever you do you are bound to get complaints. Best of Luck Bob |
Page 123 4> |
