RS600s |
Page 123 4> |
Olly4088 ![]() Far too distracted from work ![]() Joined: 10 Jan 05 Location: United Kingdom Online Status: Offline Posts: 424 |
![]() ![]() ![]() ![]() Posted: 08 Feb 06 at 10:11am |
All can anyone tell me anything about Rs600s e.g what weight they carry what they are like to sail etc.
Phantom 1298
RS600's are incredible to sail. They are very fast in most winds and are a great laugh. They require a bit of skill to sail but are extremly fun.They have a very round hull so they roll a lot which may catch you out at first but after you get used to it they are ok. I think from about 13 stone you have narrows and bellow thirteen you have widies i think. Overall a great boat for peanuts amount of money.
Greatfully Sponsored By
Would you say that 16 stone is to much to sail one then???
Phantom 1298
16 stone is probably the upper limit but is not excessive. You would suffer in light winds but come into your own in F4+ . The guy that won the Winters last two years running is around that weight, there are one or two guys in the fleet around the 15 stone mark and they are competitive. I would echo BBSCFaithful's comments, yes it is a little tippy but not beyond the abilities of a good club sailor.
Can you give me some tips on what to look out for when buying a 2nd hand 600?? I do really want one and have for ages. I think I will have to take a look at the finances and see what I can come up with. I saw one that was forsale for £1000 but it said something about the mast whats that all about??
Phantom 1298
The first generation of 600's had Angell masts which had a slight design flaw, in that they tend to break. Ideally you would want one with a Superspar mast, although £1000 is a bargain, as long as you ensure you have new for old cover on your mast for when it breaks! Check there's no play in the U-bolt that the kicker fastens to - there is no way to tighten or replace it without cutting a hatch in. The mast step can work loose but this is easily fixed with fatter/longer screws. The daggerboard can wear through the back of the case, but again this is easily fixed with epoxy. Other than that just check for cosmetic damage, in particular damage caused by scraping trapeze hooks over the bottom. A 12 year old, £1000 boat should still be structurally sound, just not neccessarily very pretty! |
Thats cool I have seen pictures of one that has a hatch next to the mast is that what they do to tighten up that u bolt?
Phantom 1298
Yes, if it's on the bulkhead then you can get a spanner through to tighten the bolt or replace it when you need to
Cool. Do you know how to get to the yahoo 600 discussion group thing?
Phantom 1298
If you go on - http://www.rs-association.com/index.asp?fleet=RS600&sele ction=mailing just put your email address in and click "join" - bish bosh!
Page 123 4> |
