Laser 161752 Tynemouth |
D-One Gold Cup Scoring |
![]() ![]() ![]() ![]() Posted: 21 Sep 16 at 4:57pm |
True, and that's something I have done an quite a few occasions when I've had a hand in race organisation. My holiday club don't run line starts, the reason probably is that we encourage novice/non racers to take part and, as the start is possibly the most complex part of the race, beach starts allow them to join in with minimum embarrassment. It does seem to work as we've managed 20+ boats at nearly every race this year ranging from Mirrors and a Devon Coble to a Musto and a 49er.
Edited by Sam.Spoons - 21 Sep 16 at 4:57pm |
Tom J ![]() Groupie ![]() Joined: 10 May 07 Online Status: Offline Posts: 49 |
Err... for 99% of events the SIs on tie breaks (or anything else) don't have to follow the ISAF / World Sailing format. The rules and guidance are written primarily for top end of the sport but as has been pointed out that doesn't make it necessarily applicable to everyone. It's not gospel, event organisers should use it as a basis and then tailor them to suit whatever participants are involved.
Obviously not all clubs or classes will want to deviate from the guidance but if you don't like an SI there's nothing to stop you questioning it or suggesting an alternative with the organisers... |
But if the hotshots take an early bath it gives us ordinary mortals a chance of at least one decent race result to brag about
Last event I did had a non discardable last race. Happened to boost us up the fleet, having had a bad first day, but I'm not entirely happy with the concept. Why not no discards, and accept that bad luck is just the way life is sometimes.
Saraband ![]() Newbie ![]() Joined: 19 Jun 13 Online Status: Offline Posts: 7 |
Giving some relevance to the last race score at least keeps more of the fleet on the water for the last race, rather than seeing the event leaders bailing out after perhaps just one race on the last day so they can get back ashore for an early shower and pack-up.........personally I need all the races I can to get anywhere decent a score!
Change for changes sake very often I feel. Many years ago we used the discards to break ties, then it became common practice to use 'count back' with the most first places, then the most seconds etc and now this daft 'medal race' system! If you're going to do a 'medal race' then do just that, all previous races are qualifiers, the top ten get into the medal race and whoever wins gets the gold. OTOH I definitely wouldn't favour that method and count back seems the fairest to me. I also preferred the ¾ point for first place race winners bonus which served to reduce the likelihood of a tie but that's long gone too.
JohnJack ![]() Far too distracted from work ![]() Joined: 12 Mar 13 Online Status: Offline Posts: 246 |
But what if you have your bad luck in the last race, surely using the discard rewards better overall performance? We once did a handicap regatta with three races, last race was worth double and counted. Bit like a gold medal race. We won the first two races, then the course was changed before race three because "we were getting too much of an advantage by putting the spinnaker up" which nullified any spinnaker legs. We came second in R3 and second over all with a (1),1,4 = 5 The winner had a (5),2,2 = 4 Felt a little hard done by......... |
Maybe when sailing has been dropped from the Olympics we will be able to go back to two hour races, triangle sausage triangle, finishes at a windward mark and tie breaks on the discard
Happily living in the past
If we accept discards as being a way of coping with bad luck it makes sense for discards to be discards.
Last race countback is a crude way of identifying someone who has been getting faster as the series progresses, which is as worthy an aim as any. |
Broken on the result of the last race ... seems fair enough and simple to understand without having to revert to the full series scores. You always need to brake ties ...
