New Posts New Posts RSS Feed: Slot Gasket
Slot Gasket
craiggo View Drop Down
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Topic: Slot Gasket
    Posted: 08 Mar 15 at 8:06pm
So I decided that the slot gasket on the Grad needed changing so I took the old one off, measured it, and ordered new sailcloth strips from a reputable UK chandelry.
Unfortunately the strips have no eyelet with which to tension then, so what's the best way forward?
I could buy some eyelets and hammer them in.
Just punch a hole through, seal it with a hot poker and hope they hold.
Fold the end over and sew then to make a loop.
What's the consensus?
Paramedic View Drop Down
Post Options Post Options   Quote Paramedic Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 15 at 5:29pm
any of those three should work.
Woodbotherer View Drop Down
Post Options Post Options   Quote Woodbotherer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 15 at 8:05pm
Sailcloth strips? Eyelets? What sorcery is this then? Why no Hawk, glue pot and sticky fingers like the rest of us?
Edited by Woodbotherer - 10 Mar 15 at 8:05pm
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 15 at 8:50pm
Because dear Graeme, my Graduate is a wooden boat with a metallic keelband which is used to hold down a sail cloth gasket. Much easier than arseing about with contact adhesive and trying to cut a dead straight line in a piece of plastic.
Sailcloth gasket strips are secured by the keelband ahead of the centreboard case then tensioned and stuck in position with double sided tape. The metallic keel band is then screwed down and the tension can be released. The gasket is then trimmed and the other side can then be done.
I've now bought some eyelets which I will hammer in tomorrow prior to gasket fitting over the weekend.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 15 at 9:19pm
If that's all you are doing, could you staplegun them to a bit of wood and have the hole in the wood for tensioning it?
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 15 at 9:54pm
That's a very good idea Jim.
patj View Drop Down
Post Options Post Options   Quote patj Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 15 at 6:18pm
For slot gasket newbies here's the link to Mike Mac's article
http://www.wayfarer-international.org/WIT/maint.repair.ref/CB.rudder/Slot.Gaskets/MikeonGaskets1.PDF
Edited by patj - 12 Mar 15 at 6:19pm
Post Options Post Options   Quote craiggo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 15 at 8:44pm
patj, that is indeed the guide by which I work!
