Sailing in tide..quiz. |
Page <1 56789 11> |
| Author | ||
Sam.Spoons
Topic: Sailing in tide..quiz.Posted: 03 Oct 17 at 9:55pm |
Sorry Doug, I was trying to answer mozzy's 'supplementary question'
Not sure I have the answer right but based on 'conveyer belt' theory?Edited by Sam.Spoons - 03 Oct 17 at 9:56pm |
Sam.Spoons
Posted: 03 Oct 17 at 10:04pm |
I remember Raceboards Open Meetings at Morecambe many years ago, I got there early one year and helped set the course marks with the aid of a wheelbarrow (and, incidentally, collect them the same way after the event)
happy days...... |
iGRF
Agreed, but then B could still short tack, onto the starboard layline and force A behind and round first Edited by iGRF - 03 Oct 17 at 10:05pm |
Guests
Posted: 03 Oct 17 at 10:14pm |
This conveyor belt theory. Why is it assumed all boats drift downtide at the speed of the current? Isn't that like assuming all boats can run downwind at windspeed?
Guests
Posted: 03 Oct 17 at 10:22pm |
All boats do drift down tide at the speed of the current. Unless you're sailing them through the water. In which case they will move in a direction over land which is the sum of those two vectors (the tide and the sailing). Trust me, when the wind drops to nothing, and the tide is flushing out the harbour, all the boats, 49er to oppie, all drift out the harbour with equal hopelessness!
Edited by mozzy - 03 Oct 17 at 10:24pm |
Sam.Spoons
Posted: 03 Oct 17 at 10:38pm |
In a flat calm that must the case (well actually won't they drift slightly slower than the tide due to air resistance)? TBF that might slow them by a fraction of a knot........ "Pedant's rule OK?"
Guests
Posted: 03 Oct 17 at 10:51pm |
As a pondie I'm clueless but intrigued.
Boats aren't rigidly attached to the water, the water flows past and hydrodynamic forces are imparted. I can't see why they should be the same regardless of the type of boat, in which case I can't see why they drift off at the same (current) speed. Therefore, if not all boats slip at 1.5kts in the example above, the winning tactics might not always be the same?
423zero
Posted: 04 Oct 17 at 7:25am |
They don't, amount of boat in water, plus wind resistance, handicap fleet, different boats react differently.
sargesail
Joined: 14 Jan 06 Location: United Kingdom Online Status: Offline Posts: 1459 |
Posted: 04 Oct 17 at 7:41am |
But the wind resistance is just the gaseous fluid motion bit of the vector. In a flat calm the rate of drift is the same. Seen it in the Cherbourg Race couple of years ago. Heaps of different boats drifting together. Possibly you could have assessed that the much heavier ones had momentum and took longer to start drifting the other way when the tide turned. Or that might have been the beer we were drinking for breakfast.....
Sam.Spoons
Posted: 04 Oct 17 at 8:49am |
Surely, in a flat calm, as soon as the boat starts to drift with the current an apparent wind equal to the speed of the current will be generated? E.g. in a 3 knot tide with no actual wind (as measured by an anchored boat) any boat drifting with the current will feel a 3 knot breeze?
Page <1 56789 11> |
