Hiking technique |
Page <1 34567 8> |
![]() ![]() ![]() ![]() Posted: 14 Sep 17 at 1:15pm |
Unless it's windy I really don't think flat is always as fast as they say anyway. Less wetted area slightly heeled, we'd never sail a board flat unless it's blowing and we're planing.
Edited by iGRF - 14 Sep 17 at 1:16pm |
It depends completely on the hull design. Some are much more tolerant of a few degrees heel than others.
Wiclif ![]() Groupie ![]() ![]() Joined: 04 Oct 05 Location: United Kingdom Online Status: Offline Posts: 81 |
OK, so I am sad too
Using the highly technical straight edge of a TV remote, it seems to me that half of the heel is because the rig is not perpendicular in the boat, as the rig is angled more than the hull |
Slack rig is 'de rigure' on the Blaze ;)
One of the interesting things with the laser is that when it is fully flat the daggerboard starts to slop around, which is another reason you see them sailed slightly heeled.
You joke about the spirit level but a simple inclinometer is a very overlooked bit of kit, if only for motivation to hike harder! Also interesting is that in high end keelboats (Fast 40, TP etc) it is quite common to sail to a heel angle downwind rather than a wind angle or target speed.
bustinben ![]() Far too distracted from work ![]() Joined: 15 Oct 06 Online Status: Offline Posts: 288 |
Lasers are a little different to most - the freeboard is so low that completely flat doesn't work in all sea states because the waves slap you even if you straight leg hike. You also need a slight bit of heel for your upwind kinetics to be effective. Slight heel + kinetics is much much faster than flat with no kinetics.
Hmm kinetics? Would that be the same kinetics the Miracle mums keep shouting RR42 at me everytime I move a cramped muscle down the lake?
Kinetics = ooching, rocking and pumping = cheating
By The Lee ![]() Posting king ![]() Joined: 06 Aug 17 Online Status: Offline Posts: 114 |
Expect that isn't true is it...
42.2 Prohibited Actions Without limiting the application of rule 42.1, these actions are prohibited:
Page <1 34567 8> |
