Daggerboard Repair |
Page <123 |
Patrick ![]() Newbie ![]() Joined: 18 Apr 06 Location: United Kingdom Online Status: Offline Posts: 4 |
![]() ![]() ![]() ![]() Posted: 20 Apr 06 at 8:34am |
Its not a great phot but you get the idea. Garry, many thanks I will see if I can find the Laser advice.
Pat |
I would only use plastic padding (car or marine) if it was cosmetic damage. If there's any risk of load in the area (and remember you stand on the C/B) I would use resin and filler powders / fibres.
Isn't there some C/B repair advice on the Laser site? |
Garry
Thanks for the tip on Plastic Padding. However comment from Tim and Stuart make me inclined to post a photograph. I'll try and do that tonight. I think that there is about a 1x6cm exposure of the core. Many Thanks. |
John Wilson ![]() Newbie ![]() ![]() Joined: 04 Oct 05 Online Status: Offline Posts: 26 |
I'm a big fan of plastic padding, I use it to fix bits on my centerboard all the time. The white stuff looks just the business too, although it's harder to get. I think it's called "Plastic Padding Marine Filler". The more standard stuff is green/grey & is made as car body filler & can be picked up in most hardware store. It is the same stuff - it just doesn't look as cool as white. It should fix most minor centerboard & rudder problems. Although if it is a bigger chunk, around 3cm or bigger I wouldn't really know what to use! Hope this helps. |
i'm sure we can advise on how to mend your dagger board but pictures would help a lot as it would mean we can tell which is the best meathod of repair for the damage
Could you post some photos of the damage? The advice will be much more meaningful for you if we know exactly what the problem is
No doubt I am not the first to damage a daggerboard. I am new to dingy ownership (and thus maintenance) and have taken a chunk out of the bottom of daggerboard on my RS Vareo. The core is now visable and clearly in need of attention. Which capable of doing the job I am unfamiliar with either technique nor products. ANy advice gratefully Received.
Pat |
Page <123 |
