Laser 161752 Tynemouth |
Alto Refurb |
Page <123 |
![]() ![]() ![]() ![]() Posted: 02 Jun 15 at 12:51pm |
I'm surprised to hear the Alto isn't self draining anyway.... That's a bit of an oversight isn't it?
Woodburner ![]() Far too distracted from work ![]() ![]() Joined: 13 Mar 15 Location: Folkestone Kent Online Status: Offline Posts: 332 |
The beauty of epoxy filler, a sander and a good paint job.. unlike that wood stuff that rots from within..
That my friend is understatement of the week.
skslr ![]() Posting king ![]() Joined: 24 Jul 06 Location: Germany Online Status: Offline Posts: 139 |
You could do “dinghy land” a favor and drive the development
of a “single wire skiff-type dinghy for two grown ups” following the ISO / Laser 4000 forward. The RS800 failed in the single wire version and 29er, RS500,
V3000, Laser Vago etc. are just too small. Cockpit · Not having a double floor cockpit is a step back compared to all these and even many “traditional” classes other than the 505. To save some weight and get the centerboard closer to the water when capsized you could than cut out the side tanks like this http://www.mader-boote.de/neue-boote/korsar/·
Cutting down the centreboard case will also save
some weight, control lines could be led to (and through) side decks as shown
instead. ·
An aft briddle would allow to remove the mainsheet
hoop. Less weight und way better optics. ·
Same for the mainsheet jammer, Auto ratchet
block on the boom should work just fine. ·
If the added stiffness of the double floor
allows a more open transom design would make crawling in if all went wrong easier and look
much better. (And make sure the builder did not hide some wood there) Bow ·
Some shiny carbon thing for the chute opening
would be a lot more stylish ·
The sheaves to the right and left of the pole
look so 1960s, replace by something like this https://www.coastwatersports.co.uk/selden-cheek-block-p-2304.html ·
Chute obviously needs to be black J AltO still got many
things right, so there is some potential! |
Thanks skslr, excellent advice, the hoop was going anyway and I was going to trim the centre console there is way too much of it. Tbh the side tanks don't really support it that high out of the water but I guess they might if the bottom were to thick, it would be an absolute joy if it were double bottomed and done in the way you suggest, good to see someone else has some vision.
I've ordered those two Selden cheek blocks I can mount them so they are further outboard, I quite like those Turbo 60's thingies they came to me wrapped around a can of Frey bentos pie, given to me by a psychologically disturbed young man who I managed to save into the heaven that is windsurfing. Regrettably he took to swimming in birds mess and has caught pneumonia he's not expected to survive well not in the same form we knew him..
Edited by Woodburner - 02 Jun 15 at 3:22pm |
Page <123 |
