New Posts New Posts RSS Feed: Scratched Hull??
Scratched Hull??
tmoore View Drop Down
Post Options Post Options   Quote tmoore Quote  Post ReplyReply Direct Link To This Post Topic: Scratched Hull??
    Posted: 05 Jun 08 at 3:44pm
i wouldnt wax a hull!!  Unless its a teflon based product, car wax stuff increases surface tension with the water.
thats why after i applying wax to my boat i get more beading of the water droplets. however, i wax it in order to get a nice shine and make the boat look nice and in order to protect it. it also means when it gets t-cut the max is what is removed in order to be replaced with new, shiny wax
but for outright speed just sand with the smoothest wet and dry you can find. it just looks dull afterwards.......... that said, hitting one wave wrong in a race will make more difference..... entirely up to you
Landlocked in Africa
RS300 - 410
Firefly F517 - Nutshell
GBR884 View Drop Down
Post Options Post Options   Quote GBR884 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 08 at 3:54pm
i dont tend to hit waves on alton!!
But then the Lymington event will be my first coastal sailing in my 600 and i'm sure i will be hitting alot of waves badly!!
Adam
timnoyce View Drop Down
Post Options Post Options   Quote timnoyce Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 08 at 9:14pm
Waxing the hull with something like autoglym will help to prolong the life of the gelcoat, and preserve the colour too. Not so important on a white/grey boat, but on coloured hulls it makes a difference.
Webmuppet View Drop Down
Post Options Post Options   Quote Webmuppet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 08 at 9:28pm
I guess that if you are going to use a wax polish on a custard coloured boat, you might as well check out the range of coloured ones available.........I thought that I'd be helpful and find out if Turtlewax do a yellow (don't think that they do, but I'm sure that I've seen something similar in Halfords) however I found that they've recently launched a range of Marine cleaners/polishes on their website - Clicky
Cheers,
Nigel
Graduate 2530 'Galaxy'
Post Options Post Options   Quote GBR884 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 08 at 9:51pm
Thanks Nigel!!
What would be better? Gelcoat sealer or gelcoat wax?
Adam
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 08 at 10:40pm
Hi Adam,
I only T-cut my hull after sanding the repairs down with 1200 grit wet and dry. gets it nice and shiny. To be honest polishing and stuff will make minute differences, and tactical decisions or bad tacks will make far more difference on the 600. If you are going to lymington I will look out for you, a yellow boat wont be too hard to spot. I've got purple progrip on the side decks, come and say Hi.
Also International 14, 1318
Villan View Drop Down
Post Options Post Options   Quote Villan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 08 at 11:30pm
Kinda along the same lines ... Whats best for bringing a dirty hull back up to colour again?  (tyre marks from jettys, slightly off color gelcoat in areas from silly people strimming around my boat, and splattering the hull with chopped grass etc etc)
White gelcoat boat, tried Muc Off .... Didn't really have much effect. I'm not really after one of those superfast/"nano" coatings ... Just something that I can look at and think .. " oooh ... shiiiiiiiiny ... "
Looking back through the thread, looks like Autoglym or a wax (turtlewax?) would do the trick ... But just looking for a few pointers before I go spending money!
TandyUK Servers
Post Options Post Options   Quote GBR884 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 08 at 9:53am
Sorry Mike i've been given some work at Alton on the saturday so i wont be there anymore....I need the money!!  Will you be doing Oxford training or Broadstairs?
By the way, i did use 1200grit followed by Feckler and T-cut and now it's fantastically shiny!!  Its fast as well......Isn't it Splosh!!
Adam
Splosh View Drop Down
Post Options Post Options   Quote Splosh Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 08 at 5:14pm
Adam
... at least I didnt forget the course! Tongue
RS300 - 346 :D
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 08 at 4:52pm
I can't get to any of the 600 events apart from the ones on the south coast.
