New Posts New Posts RSS Feed: RS600 Help
RS600 Help
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Topic: RS600 Help
    Posted: 25 May 06 at 3:44pm
I basically invert the mast on the forestay and once the sail's up it's fairly straight rig.
For a 600, thats some EXTREME rig tension!!  When i first got mine i talked to some of the old skool 600 guys and their general rule of thumb seemed to be "floppy is fast", the idea being you should set it to you weight so that as you put your weight on the wire the windward shroud should just go floppy.  On a loose gauge i doubt im evening hitting 20 (im quite light ya see).
hhmmmmm i think i may try some extreme tension and see what it feels like, could well be that ive been sailing with a horrible shaped rig!
Any chance of you going to the 600 open at weymouth 1st wknd of june??
would be nice to race against some other Y&Y forum members!
Doug
Edited by Doug.H
29er397 View Drop Down
Post Options Post Options   Quote 29er397 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 06 at 1:52pm
bov did my tillers, same tube as the rooster ones which is almost indistructable! only cheaper from bov. only complain i have is the crappy UJ's but the are on the 29er, not bovs fault.  sea sure UJ's deffo the best.!!
Matt Jackson View Drop Down
Post Options Post Options   Quote Matt Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 06 at 12:47pm
enjoy the boat and don't do what I did last night which will cost £100 for a new extension... (or a visit to the fishing shop if I follow the sound advice from the IainC)
I recently got a 2m Harrison extension from P&B for £75. It's the business and has taken a lot more abuse then the crap Holt one (I think they only get crap over a certain length - mine was 2.1m) I broke last season.
Incidentaly I made a Streaker and Oppy sailor quite happy when I presented each of them with a 'new' carbon tiller extension. I guess if you're lucky with where it broke you could sell both ends and recoup some of the replacement cost?
Edited by Matt Jackson
Laser 203001, Harrier (H+) 36
Isis View Drop Down
Post Options Post Options   Quote Isis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 06 at 12:00pm
Im saying nothing.
rich96 View Drop Down
Post Options Post Options   Quote rich96 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 06 at 8:40am
Hi
The mast will be raked until you tighten the forestay.It also doesnt sit neatly on thre step.
It should not be hugely raked once you've got lots of forestay tension on - nothing like a Contender.
Go onto the RS Web site and look at the Tuning section for the 600 - lots of useful docs to print off. -  http://www.rs-association.com/
Good luck
Shaggy View Drop Down
Post Options Post Options   Quote Shaggy Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 06 at 7:43pm
 Hi people,  i have just purchased a rs600. just a question on the rig setup. there seems to be alot of rake on the mast before the sail is even on, it doesnt sit flush on the mouting on the deck. could this be down to the shrouds being to short or are they all like this? if anyone has any pictures side on showing there mast and step would be much appreciated.
RS600 (662)
