Raising rudder |
Page 123> |
fudheid ![]() Far too distracted from work ![]() ![]() Joined: 21 Apr 11 Location: 51.53 N 01.28 E Online Status: Offline Posts: 241 |
![]() ![]() ![]() ![]() Posted: 21 Apr 11 at 1:34pm |
Are you allowed to raise your rudder when racing?
For example to cheat the tide or go across a bar at low water? we have lots of lasers that keep whipping us because they can lift everything and cut through sand banks... ![]() |
It depends on the class rules. In a Laser, not you can't.
Ex-Finn GBR533 "Pie Hard"
Do class rules apply when you are handicap racing? And would the majority of people know that it is against Laser Class rules to lift your rudder why sailing?
Bonnie Lass Contender 1764
They apply if you say you're sailing a Laser. If you said it was a Laser like boat with a variable rudder angle, then you'd be ok.
im guessing your racing at felixstowe,
i used to raise my foils and sail over the bar, its just a good tactic, and nothing in the club rules says you cant, normally they make you go around the green and red markers to stop you going through the cut |
TWO FRANK-Hunter Impala
I think its relatively standard practice on a Hobie cat to help reduce drag in light winds. They normally only lift one though.
No approved on a Dart 18
Absolutely and in their entirety. RRS 78. |
(j) The rudder shall be maintained in the full down
position except whilst racing in water less than 1.5m deep unless otherwise specified in the sailing instructions. I take it back... |
Crikey- a Laser rule with a common-sense allowance? Blimey! |
Al |
[QUOTE=Lukepiewalker](j) The rudder shall be maintained in the full down
position except whilst racing in water less than 1.5m deep unless otherwise specified in the sailing instructions. I take it back... Where's it say that in the RRS?Apparently a local RYA P.O.R. said that there has been protests upheld and it is not allowed to adjust rudder when racing. Unless it is designed to do so like a foil....... Just can't find the rule |
Page 123> |
