New Posts New Posts RSS Feed: Change the PY System?
 Post Reply Post Reply Page  123 15>
Poll Question: Would you like to see the Laser Fixed & Centred.
Poll Choice Votes Poll Statistics
6 [16.22%]
31 [83.78%]
You can not vote in this poll
Post Options Post Options   Quote iGRF Quote  Post ReplyReply Direct Link To This Post Topic: Change the PY System?
    Posted: 21 Jul 17 at 2:15pm
Following the many often heated PY discussions the suggestion of fixing the Laser (say at 60, or 600) and all the other handicaps calculated to pivot around it, obviously with the continuing caveat of individual clubs tailoring the system to their own requirements remaining in place.
Simple yes no answer, naturally a trial would have to be organised first.
What do you think and why?
Post Options Post Options   Quote iGRF Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 2:20pm
Can't seem to edit the opening post to credit A2Z for the suggestion.
GarethT View Drop Down
Post Options Post Options   Quote GarethT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 2:31pm
No.
Until there is a system that takes into account wind, sea state, tide, course, etc no handicapping system will ever tell you who was the best - just who sailed well in a boat well suited to the conditions.
Given it would never be practical to do this at a club level, why not just accept that that it's supposed to be a bit of fun and go out and enjoy yourself?
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 2:38pm
Maybe.
Supposing there was coherent evidence that the demographic of Laser sailing on PY was changing, resulting in a drift in their performance?
Should fixing the Laser make any different to the Laser: <any boat> ratio?
Are you just asking that every value in the 2017 list is multiplied by 600/1097 and every value in last year's list by 600/1095?
Apart from rounding errors, I cannot see that would have any impact on the e.g. RS400:Merlin ratio.
Maybe those rounding errors inject noise into the system.
It would be interesting to run the process over many years data and see if it helps things converge.
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 7:35pm
I can't see any merit.
Having a fixed comparator may seem attractive at first sight, but what is the actual benefit? All that matters is that the relatives remain correct.
And you then create the problem, that others have raised that if your fixed point moves, as it can legitimately under PY you have to fiddle everything else.
Peter
Ex Cont 707
Ex Laser 189635
DY 59
KazRob View Drop Down
Post Options Post Options   Quote KazRob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 8:29pm
It's worth reading 'Yacht Rating' by Peter Johnson just to understand how much the search for a perfect sailing handicap system is a futile one. But it has occupied many a mind in both inventiveness and protection of vested interests. A fab book.
OK 2249
D-1 138
Post Options Post Options   Quote KazRob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 8:35pm
(oh and a serious question for iGRF). I've just bought a big ol' raceboard (Equipe II) for a bit of all-weather summer windsurfing. Any idea what PY I could use if I wanted to join in with a bit of club racing just for a bit of fun?
OK 2249
D-1 138
423zero View Drop Down
Post Options Post Options   Quote 423zero Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 10:29pm
No.
All this hysteria is totally unnecessary, PY is not set in stone, clubs can locally adjust.
turnturtle View Drop Down
Post Options Post Options   Quote turnturtle Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 11:07pm
NO- Laser sailing is riddled with variables in its own right.   Using it as a benchmark, beyond its generous offering of real world results data for PY, is utter preposterous
Post Options Post Options   Quote iGRF Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 17 at 11:18pm
Equipe 2 with a 7.5 Raceboard sail we suggested 950 up to force 4 and 800 at Force 4 and above.
With a 9.5 Sail up to force 4 850 and 800 at Force 4 and above.
That was a few years back now, I'm not sure what we're currently racing them off I think it settled around 875 which was about the speed of a Musto Skiff.
