New Posts New Posts RSS Feed: sail coating
sail coating
sawman View Drop Down
Post Options Post Options   Quote sawman Quote  Post ReplyReply Direct Link To This Post Topic: sail coating
    Posted: 26 Apr 13 at 6:22pm
can anyone feedback whether that sailkote stuff is worth investing in?
my spinny has lost most of its crispyness, I wondered if it might help its passage into and out of the sock, esp when its damp
robin34024 View Drop Down
Post Options Post Options   Quote robin34024 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 13 at 7:20pm
Don't a lot of people use holt prolube around the chute entrance to let the kite flow in and out easier?
RS400atC View Drop Down
Post Options Post Options   Quote RS400atC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 13 at 7:26pm
Any silicone spray helps.
GybeFunny View Drop Down
Post Options Post Options   Quote GybeFunny Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 13 at 9:59pm
I have used the holmenkol stuff, it doesnt make the spinnaker crispy though but it does make it slippier for a while.
Medway Maniac View Drop Down
Post Options Post Options   Quote Medway Maniac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 13 at 11:29pm
Fabsil and other cheaper alternatives to Sailkote discussed here:
I use Nikwax TX.Direct wash-in waterproofer* every few months to good effect on my now 6 year old kite.
[* cheaper if you buy the 1 litre bottle]
patj View Drop Down
Post Options Post Options   Quote patj Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 13 at 7:26am
We spray with BSK Knitting Spray which is designed to make yarn run smoothly through a knitting machine. Available by mail order from BSK in Bedford. It's good on bolt ropes too.
Haven't tried Fabsil on a kite though we've sprayed it onto our tents many times with a garden sprayer. It's available from any camping shop.
Post Options Post Options   Quote sawman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 13 at 7:49am
neat, that helps
spray? paint? or bucket?
Post Options Post Options   Quote Medway Maniac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 13 at 11:11am
Originally posted by sawman
neat, that helps
Nikwax?  In a bucket.  Seems to be important to put the article in the hand-warm water, then add the Nikwax (as directed) rather than mixing the water and Nikwax first.
Noah View Drop Down
Post Options Post Options   Quote Noah Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 13 at 11:28am
I've applied Fabsil to tired kites using both a manual trigger pump spray and a pressurised, pump-up garden spray. Both worked well.
Nick
D-Zero 316
Post Options Post Options   Quote Medway Maniac Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 13 at 11:30am
Should add that I rinse the salt out of my kite every Sunday, and hose the cute with fresh water, which I suspect is at least as important.
