New Posts New Posts RSS Feed: Carp landing poles as tiller extensions
lozza View Drop Down
Post Options Post Options   Quote lozza Quote  Post ReplyReply Direct Link To This Post Topic: Carp landing poles as tiller extensions
    Posted: 20 Jul 05 at 12:38pm
What are your tips on using carp landing poles as TEX's?
i.e.
what diameter section?
Attaching the poles to UJ's?
What grip to use?
Do decent tackle shops chop them to the right length in the shop for you or do you have to do that yourself?
Life's a reach, then you gybe
Post Options Post Options   Quote Phil eltringham Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 12:55pm
Arn't the poles really bendy? surely that could make heading up quite difficult.
FLAT IS FAST!
Shifts Happen
Post Options Post Options   Quote lozza Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 1:04pm
Can't you just wrap more carbon round the pole or something?
Post Options Post Options   Quote Phil eltringham Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 1:10pm
just PM'd you with some details
FLAT IS FAST!
Shifts Happen
Granite View Drop Down
Post Options Post Options   Quote Granite Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 1:25pm
I went into a local fishing shop to ask for a carp landing net handle only to be laughed at because no one fishes for carp around here.
Instead I  went to a local DIY store and baught 20 bamboo canes for £2.50 and a short length of hose to join them to the UJ's
I have had some issues with the hose/UJ comination being a bit bendy but beefed that up with a short length of sail batten and all is now spot on.
The spares even came in usefull for propping up a sun shade
Bobbins View Drop Down
Post Options Post Options   Quote Bobbins Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 2:40pm
Keep talking about that bamboo...  I'm assuming you're not just using one cane - how many and what strength does this give, over what length?  ish...
www.fastsail.org
Fireball GBR 9476
stuarthop View Drop Down
Post Options Post Options   Quote stuarthop Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 3:21pm
granite only uses one cane for each extension
Jack Sparrow View Drop Down
Post Options Post Options   Quote Jack Sparrow Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 3:21pm
Carp landing net handles are real good, not to bendy, they even come
with a nice foam grip handle!
To fix them to your UJ's just cut off the metal threaded end fitting, push
in a little car filler ( P38 ) or similar having put a little parcle tape around
the UJ's and let the filler go off (so you can get the UJ out if you bust it).
Then drill a hole through and put a bolt through it with a nylock on. An
M3 / M4 should do it.
guytoon View Drop Down
Post Options Post Options   Quote guytoon Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 3:48pm
After testing about everything possible, for my cherub I bought a kite rod in carbon for about 12 £ .
They are 2meters long and 16mm diameter.
http://www.e-kite.net/catalog/tarif.php?id=4257d20f33be4& ;cat=TUB3
I'm sure you could find the same in UK and even if it isn't Cherub-DIY-Stylee it work well, efficiently without any splinter in the fingers ...
Cherub 2692 "NBS"
Strawberry View Drop Down
Post Options Post Options   Quote Strawberry Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 05 at 6:23pm
Red Wolf is the way forward. There 6ft long and should be available in almost any fishing tackle shop, especially the one in Welwyn Garden City. Leave the metal bit on, it adds strength to the UJ, or it just rips out like Tim and Andy's did. Then just drill a half inch hole in the bottom, stick the UJ in, and whack a bolt through.
