New Posts New Posts RSS Feed: Leak test
Leak test
ssailor View Drop Down
Post Options Post Options   Quote ssailor Quote  Post ReplyReply Direct Link To This Post Topic: Leak test
    Posted: 08 Jun 05 at 3:03pm
Cheers everyone whos put their point in  , weve got a feelin its where the spaceframe goes through the hull at one point, once sealed hopefully itll wont leak!! we had noticed that the boat only take the water in when its on its side , if we race and dont capsize it doesnt leak!
The New Port rule!!.
MikeBz View Drop Down
Post Options Post Options   Quote MikeBz Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 05 at 9:00am
I've had several boats which "whoosh" when you remove bungs or hatches but still take on water.  Never got to the bottom of it though.
redback View Drop Down
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 05 at 11:18pm
You've got to remember the hull panels flex in and out as you hit the waves and so some of the time the pressure is less inside than out.  A tiny leak will be alternatively sucking and blowing.  If there is water around the leak then water will get sucked in but run to the lowest point inside so that air get expelled on the next blow.  You then lift the boat out of the water and the air inside warms and expands.  If you then open the bung you release that pressure but find a small amount of water in the hull.  Its common and not to be worried about - just make sure you sponge it out, especially if its a wooden hull and especially if its likely to freeze overnight.
Scooby_simon View Drop Down
Post Options Post Options   Quote Scooby_simon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 05 at 10:51pm
the air in the hull contracts on the cold water and you can get quite a negatave pressure to suck water in
Most prolly the cause, when you then get on to the land, the boat heats up and QED + pressure
sailor.jon View Drop Down
Post Options Post Options   Quote sailor.jon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 05 at 10:02pm
hen it come to unscrewing the bungs after sailing you can hear the air escaping
this shud mean the hull is water tight or as near as dam it
Granite View Drop Down
Post Options Post Options   Quote Granite Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 05 at 9:24pm
Look for a pin hole below the waterline especialy if your boat has no breather hole, the air in the hull contracts on the cold water and you can get quite a negatave pressure to suck water in
Peter Rhodes View Drop Down
Post Options Post Options   Quote Peter Rhodes Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 05 at 8:56pm
could be the matterial soaking up water (nothing is totally inpermeable) or even the water in the cockpit!!!
Post Options Post Options   Quote ssailor Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 05 at 8:47pm
Does anyone have any idea what it means if a boat takes on water but when it come to unscrewing the bungs after sailing you can hear the air escape? to me it suggests its air tight!
