New Posts New Posts RSS Feed: Laser Vago/RS Vision/Topper Omega
 Post Reply Post Reply Page  123 11>
yellowhammer View Drop Down
Post Options Post Options   Quote yellowhammer Quote  Post ReplyReply Direct Link To This Post Topic: Laser Vago/RS Vision/Topper Omega
    Posted: 20 Sep 05 at 10:59pm
Originally posted by NickA
......... ach but forget all that, I just followed
http://laser3000.lasersailing.com/forum/topic.asp?TOPIC_ID=5 93
want one .... now.
Foir some reason that link missed the mark for me, try the one below ... first pictures of the V3000:
Edited by yellowhammer
Laser 3000 @ Leigh & Lowton SC
www.3000class.org.uk
Sumo View Drop Down
Post Options Post Options   Quote Sumo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 2:03pm
[QUOTE=NickA]
If the mast breaks blame laser.  The Vago's designed and advertised for single hand trapezing (and I don't see a weight limit specced) so if you break a mast you're doing everyone a favour by forcing laser / selden to redesign it!!!!!
/QUOTE]
I had a conversation with Laser on this issue and they don't recomend someone of my not inconsiderable weight trapezing as it will over stress the mast. In fact with my weight conditions would have to be ballistic before I would be able to go out fully on the trapeze any way, so hiking out is more than adequate!
Post Options Post Options   Quote yellowhammer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 1:46pm
yer the new 3k looks very good!!  will it race with the 3000's or will it have its own race/start at events?  cos the new one will probily be faster!!
Thanks for the feedback ... glad you like it. Jeff Vander Borght and his builders have done a great job and the V3000 should be a sweet little race boat
Once the class has voted on rule changes they'll race together with Laser 3000s, with weight equalisation for class racing only. Once a few members have V3000s on the circuit we can have a vote on whether to remove the equalisation.
Maybe in a couple of years we can form divisions within the fleet with shared starts (like the Ospreys with different Mk boats) with an overall champion. Serious contenders will buy V3000s, but Laser 3000s will still be competitive and upgradeable in all but the hull, and provide an entry level.
The challenge will be to win overall with a Laser ... I'm keeping mine (Class Secretary) so we won't sacrifice older boats. Expect Laser 3000 values to remain solid with the new life in the class.
Superb result!!!
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 12:54pm
That little moulded seat / step.  Does it have any grip?  I'd assumed it was for nervous kids and mums to sit on when being taken for a cruise.
want one .... now.
carshalton fc View Drop Down
Post Options Post Options   Quote carshalton fc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 12:24pm
International 14 1503
Sumo View Drop Down
Post Options Post Options   Quote Sumo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 10:07am
Sumo .... or anyone .... have you single handed your Vago from the wire yet? (and if not why not!).
What's it like to step out of - I can't see from the brochure pics what on earth you'd brace your feet on.   Strangely, the man in the brochure is using a tiny tiller extension, which isn't the best of adverts and does make me wonder how much laser are committed to the Vago's singlehandableness..
The laser 3k is spot on for single hand trapezing with those ridges in the deck.  My laser 2 requires a leap of faith (and a foot on the main sheet block mounting).
PS: my old l2 also has a straight mast and the gust response of a barn door - but the Vago's looks more flexible - should help make up for no taper??
I've sailed my Vago singlehanded, although I haven't trapezed, as I don't want to break the mast! The Vago has a step moduled in each side of the cockpit at the front for going out on the wire, so it shouldn't be a problem.
I had a look at the Vandercraft built 3000 at the show and they have addressed one of my major gripes, namely a lack of space, by changing to a gnav and switching to rear sheeting from the boom. Looks like a major step forward for the 3000.
Medway Maniac View Drop Down
Post Options Post Options   Quote Medway Maniac Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 12:21am
Not just the Laser 3000. Take a look at this:
CurlyBen View Drop Down
Post Options Post Options   Quote CurlyBen Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 05 at 12:11am
My experience is pretty limited on the Dart 16 (the only cat I've sailed, and that only 3 times) but they seem to use loads of rig tension, with the leeward shroud going pretty floppy in a breeze due to the power in the rig. If I'm being stupid please tell me, but how does the mast know the difference between someone on a trapeze and a shroud? The angle's slightly different but the weight on the trapeze should just unload the windward shroud, so unless you managed to start bending the mast back and loading up the leeward shroud I can't see there being a problem, which suggests the mast was dodgy. Another instructor I was talking to about cats reckoned the Dart had about 2 tons of pressure on its forestay (could be completley wrong, seems pretty high to me) but I doubt with that much rig tension you're going to totally unload the windward shroud. I'm tired so if I'm being stupid please tell me!
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 05 at 10:36pm
Edited by NickA
Post Options Post Options   Quote yellowhammer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 05 at 6:00pm
Originally posted by Sumo
The mast was brand new and it folded like a toilet tube about one third up, i.e. mid point between the bottom and the shrouds, so classic compression loading!
The pressure in the sails defines the trapezing moment that can be applied for a dinghy (although it will be subtley different for a cat). Can the 3000/Vago sail area generate enough force to take 21 stone trapezing worth of righting moment? Is the large weight trapezing close in the problem? I'm trying to picture a vector diagram .....
