Marking jib sheets |
Captain Morgan ![]() Far too distracted from work ![]() ![]() Joined: 03 Sep 08 Location: United Kingdom Online Status: Offline Posts: 211 |
![]() ![]() ![]() ![]() Posted: 14 Apr 09 at 12:40pm |
I have no idea whether this is possible or not, but does anyone know of any way to suitably (permanently) mark jib sheets, e.g. draw a line around or at least make some sort of mark so that the position of the sheet in a deck cleat is repeatable? I'm sure that I've seen something for halyards (rather than using permanent marker on the mast or deck), but I could be wrong. Any ideas? |
Stich in some thread of a contrasting colour. Sorted.Could then use some sort of vinyl or marker pen (if your sheet runs between turning blocks) on the deck to measure position.
Edited by alstorer |
Al |
We normally stitch in some lines of thread, different colours for different rig settings. Works well and doesn't rub off. I tried the permanent marker, but a combination of sea, sun and cleats means its not so permanent!
Cheers for the advice - looks like I need a needle and thread then! Trouble is that I can't even sew on a button! (I'm more Gripfill/staple gun than needle/thread.) It'll be messy, but it will work (and it certainly won't be very pimp). |
