New Posts New Posts RSS Feed: How important are smooth foils
redback View Drop Down
Post Options Post Options   Quote redback Quote  Post ReplyReply Direct Link To This Post Topic: How important are smooth foils
    Posted: 09 Mar 05 at 10:19pm
I've just spent a lot of time doing up the foils on my Laser4000.  What prompted me was the extreme care the International14 guys expend on their foils.  Being tippy - especially with the board up - we tend to come ashore with half board and whip it out as soon as it touches but this does mean a bit of abrasion on the bottom leading edge.  Similarly the rudder gets released but has to hit the bottom to tip it up - again resulting in a slightly flattened leading edge at the bottom.
How do the 14s get ashore and keep their foils so good, or do they refinish them each week?
How important is it to have smooth foils? Does anybody have any experience which will help quantify this?
Blobby View Drop Down
Post Options Post Options   Quote Blobby Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 12:32am
Read Mr Bethwaite's book - he wrote about 5 pages on the merits of mirror polished foils for reducing drag and increasing the maximum lift force available before ventilation and stalling...
James Bell View Drop Down
Post Options Post Options   Quote James Bell Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 8:26am
The thing to remember about foils is that even though they're relatively small compared to the sails, they're operating in water which is 800 times the density of air. So a well finished foil is undoubtably an effective way to better boat speed.
Having said that, maybe I should pay some attention to my own foils. The guy who I bought my 4000 off was also a windsurfer and spray painted the daggerboard luminous orange! Very good for when you capsize and also for those screaming reaches when the daggerboard is partially out of the water.
The practical answer to damaged foils is to have a training set that can be dinged etc, and a special pristine/as new set for those more important races.
IOS Sailing Community - www.iossc.org.uk
Adam84 View Drop Down
Post Options Post Options   Quote Adam84 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 9:56am
The thing you have to remember with the foils and the hull is the more perfect the finish the more effective the foils will be. A boat builder once tried explaining this to me by saying a chip or bit of damage will have a similar effect to weed in that it will disturb the flow of the water over the foils which will create more drag and slow you down (obviously not to the same extent as weed but every little counts), so anything you can do to improve this will be beneficial.
KnightMare View Drop Down
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 11:08am
Yeah foils are very important, but then again so many things are. take for example you rudder if you move it by 5degrees this has the same effect as outting you leg in the wwater to slow you down, why it is so important to use as little rudder as posible. get everything else up to perfect level and then do the foils, it will only make a diference if the rest of the boat and sailing is up the that standard.
Post Options Post Options   Quote Adam84 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 11:17am
I agree with that. You need to get everything up to the best standard possible weather it may be your boat or sailing skills, however don’t make the mistake of thinking “I don’t need to do that its only a small thing” because all the little things add up to a big thing, bringing you foils up to a good standard may gain you a few boat lengths and in a close race could make all the difference.
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 11:25am
Yeah but you can loose more from having bad sailing than through having a bad boat. But as soon as you have that sorted you canb gain boat lengths from all your boat being perfect.
Post Options Post Options   Quote Adam84 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 11:38am
Yeah sailing skills are definitely the thing to worry about first but once you get your sailing up to scratch, good boat preparation will win you races.
Post Options Post Options   Quote KnightMare Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 11:45am
Yeah, but it is important to look after your boat, all the way through otherwise when you get good you will have to spend lots of moeny/time to improve the boat enough. Just get sailing and learn how things feel and once you can sail by feel you will know if the foils or anything are getting worse as the boat will feel diferent. PS its also good for when you want to think about tactics to be able to sail by feel.
Dave S View Drop Down
Post Options Post Options   Quote Dave S Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 05 at 4:03pm
By being very careful! Actually, it probably makes more difference with our laminar-flow sections because there's a tangible benefit to keeping everything laminar, whereas with a turbulent-flow section (which I assume the production boats have) there's much less downside. But a good 14 crew is super-careful with the foils, and is willing to get very wet in order to avoid pranging them. If you sail in with the board half-way up and jump out when the water's still 4 feet deep you should be absolutely fine. At an unfamiliar venue, use other crews who have already jumped out to gauge the depth.
We do also do a fair bit of sailing in Chichester Harbour, where running aground is much more likely and can happen at considerable speed. Options here are to take less risks when travelling at speed or where you believe the bottom may be hard, and to pay close attention to other boats! It is often better to be twin wiring when you hit the bottom because the board only has to absorb the momentum of a relatively light boat (helm and crew go round the forestay). But 14 boards are pretty well-built so even a big crash just tends to wipe out the bottom couple of inches, which are relatively easy to reconstruct (an hour or two's work).
As an aside, the Ovi 1 14 was (some time ago) sold with a stock 49er board, which was pretty useless. Just about everyone threw it in the attic and had a decent one built, and it made a massive difference!
Cheers,
Dave
