New Posts New Posts RSS Feed: The big bear away....
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Topic: The big bear away....
    Posted: 10 May 08 at 9:44am
One of my most common moments of ineptitude when sailing my contender is not being able to survive the bear away round the top mark when its windy.
I do all the text book stuff - move right back etc, but the boat just accelerates too fast and I usually fall off the side, do a quick inspection of the foredeck and then go for a little tow....
Apart from attempting to sail a boat that's too much for me, what am I doing wrong?
Skiffybob View Drop Down
Post Options Post Options   Quote Skiffybob Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 9:52am
Can't really comment about Contenders, but have plenty of experience in a boat that loves to do this (i.e. 12ft long and vasty over-ragged).
Have you eased the kicker? If not this will drive the nose down. Also, ease the main before you start pulling the tiller. What you need to do is to pull the boat on top of you, then bear away. A common mistake that people make is to get the timing between mainsheet and tiller wrong. NEVER bear away first because the boat will heel to leeward, and this will drive the nose in. Heel it to windward (over on top of you) and push with your front foot (a bit like you do with a board).
Hope that helps.
foaminatthedeck View Drop Down
Post Options Post Options   Quote foaminatthedeck Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 10:01am
Do you have any toe straps across the back of the boat? Mine are diagonaly across the floor of the cockpit at the back. My back foot goes in the straps with my frount foot on the side. Sorry no picks at the moment. When I started using these it stopped me fall off the side as much.
Lark 2170
Oli View Drop Down
Post Options Post Options   Quote Oli Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 10:23am
agree with skiffybob about bringing the boat in ontop of you and easing the kicker.
i used to blow kicker and cunninham at same time then let the board up a wee bit then ease the main just before you bear off.  never got sent round the bow.
the only time i felt i need the toe staps was in 40knts dead down wind, but then again im not a small chap so i could use my weight more affectively in staying on the boat.
Contender 541 View Drop Down
Post Options Post Options   Quote Contender 541 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 1:03pm
Kicker off
Cunningham off
Board up a bit
Hook on - if you are not already
Heel it over on to of you a bit
Ease the main
Push the tiller
Step out backwards and take the main with you
Let me know if it works - I always had the same problem
Crew on 505 8780
Iain C View Drop Down
Post Options Post Options   Quote Iain C Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 2:44pm
541 should'nt that be pull the tiller?
I sometimes find doing the bearaway in little steps can help if it's really gnarly...you kind of feel how the boat is loading up through the tiller and sheet loads and sail it accordingly.  Bear away onto a close reach (having done all those other things mentioned above)...if the nose starts to go down, the speed coming on, the hull really starting to plane and the apparent going forward might mean that she pops up and gets settled before you finish the bearaway.  We're only talking fractions of a second here, a bit like centralising the tiller mid gybe really, but it might just be easier than expecting to bear away from upwind in a F5 to a dead run in one swift manoevre.
Not sure how heavy you are but the Contender board is massive, you can probably get away with having it really quite a long way up.  And don't steer too much, get the trim right and the windward heel right and it will more or less bear away by itself.  Yank on a load of rudder  (especially if heeled) and it kinda makes the stern come up and the bow go down.  Release the "pressure" out of the sail with the kicker and mainsheet, steer the boat into the bearaway by heeling it on top of you, and the rudder just follows along behind as more of a "trim tab" than a proper steering device.  If you get it wrong and end up in the drink a quick stab with the tiller will usually pick you up again...
RS700 GBR922 "Wirespeed"
Enterprise GBR21970
Bavaria 32 GBR4755L "Adastra"
Post Options Post Options   Quote Contender 541 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 3:17pm
Bugger
Crew on 505 8780
skiffcrew View Drop Down
Post Options Post Options   Quote skiffcrew Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 08 at 6:45pm
sorry if it sound obvious but move the angle of your body in relation to the boat futher back, i.e. lean back, and by bending your back leg more, you can drive the nose of the wind, as in a fast bear away the force of the acceleration will force you off the side making you go forwards.
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 08 at 8:42am
in the 600 i dont tend to bother with the control lines until im settled down sitting in the boat having born away. Just make sure that as you come up to the mark the boat is FLAT then ease the main, walk backwards, and find a footloop. now, ditch as much main as possible, pull the tiller a tiny bit and hang on.
Also International 14, 1318
Merlinboy View Drop Down
Post Options Post Options   Quote Merlinboy Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 08 at 10:24am
you dont dump the kicker??? in big winds mike i think the 600 would just huck you in unless you control the sail through things like kicker
