Differences between Splash and Flash? |
![]() ![]() ![]() ![]() Posted: 12 May 06 at 9:54am |
My sons in a Oppy and my wife is getting back into sailing and is a
lightweight (48kg). Getting a Splash / Flash seems a good option. But there doesn't seem to much info about the Flash anywhere I can find. What are the differences? I'm pressuming it is just sail size? Do many people sail Flashes in the UK? e.t.c e.t.c Let's us know. Cheers Jack |
Yes I thought about this for the same reason as you. As far as I could see it was just sail size. Mostly sailed in the east of England. Check some of the clubs in East Anglia for more info.
Cheers |
Jack,
From the Splash CA website (it is buried). The Flash has a bigger sail and a longer boom. Splash sail area 5.5 sq m PY 1184 Flash sail area 7.0 sq m (same as a Laser 1 I believe) PY 1130 (provisional) As for numbers, I am not sure. If you look on the CA website you may be able to get an idea of where fleets are and of second hand boat values. You might find that the Byte is a better bet and the new rig does look good :-). Paul Edited by jeffers |
Yeah.. I like the look of the Byte with the new rig. It just seemed a better
long term bet to get a Splash, so when the nipper gets bigger he can move into an International class that's more of a boat than a Topper and designed for kids e.t.c And my good lady can sail it till that happens. Flash sail area seems a bit big for a 48kg lady though. And form the look of it doesn't seem to be sailed much in the Flash form. |
If the nipper really gets in to it you could always let them habe the byte until they outgrow it then purchase a chesp old Laser (apologies for the language). Then you have got international class status in it's abundance.
For my money I would go for the byte though as the running costs will be lower (ie you dont need to spend a fortune on new sails every couple of years). Also when they outgrow the Byte they may want something a little more exciting (such as a Cherub......) Paul |
CII BYTE CII BYTE CII BYTE if 40Kg Singapore girls can do a Byte and me at 75Kg can have a laugh in 10kts with a CII rig you are onto a winner... |
So it works that well then? I had a go of Ian's boat when he and Julian were still playing with it. It seemed to be pretty good but I had nothing to compare it with. Interesting to hear you say it has the weight range Ian wanted. Was your weight competitive? |
world champ weighs 73kgs, top team in the world IMHO comes from singapore weight low!! It is an excellent rig. I'm at the top end 68kgs and have only just started in the boat and was competetive aginst 2 europes in force 1 gusting 2 sailed by 2 decent sailors who are loads lighter than me. They beat me by 2 mins in a 70 min race so about right on handicap and i've still got lots learn about the boat.
You're no convincing me that 48 kgs is a good idea with what you just
posted?! ![]() |
