Wanted Int Moth Hull |
phantom871
Joined: 12 Apr 06 Location: United Kingdom Online Status: Offline Posts: 86 |
Topic: Wanted Int Moth HullPosted: 12 Apr 06 at 2:41pm |
Hi Does anybody know of a deceased international moth going spare. I have a few idea's i'd like to try out. I am on a restricted budget so would only concider cheap or free hulls. If you have a hull that is just in the way I am interested. Would preffer a thinnish hull but not to thin! I only need the hull. I dont mind holed or cracked hulls. I am in Mk but will travel for the right hull!
Many thanks
Edited by phantom871 |
If its bent pull harder
Simon Propper
Posted: 12 Apr 06 at 3:10pm |
Hi James There's a broken Magnum hull at Grafham, I'm sure you could have for free. The owner has given away all the gear so apart from fixing the hole in the bottom it would cost a bit to put back on the water since you would need a rig, foils wings and tramps. A better route may be to buy a complete boat and try out your design ideas from there. Our website www.int-moth.org.uk usually has boats for sale from a couple of hundred pounds. You can place a wanted ad for free on the site and you can join our yahoo group and post your request there By the way, these days, no hull is too narrow. They're rarely in the water. Have fun Simon |
phantom871
Posted: 12 Apr 06 at 3:39pm |
Its not going to have a sail on it! I am going to put riggers on it and use it to build up my fitness! |
phantom871
Posted: 12 Apr 06 at 3:41pm |
Sounds like I have have found the hull!
phantom871
Posted: 12 Apr 06 at 3:54pm |
Simon
Who should I speak to to get my hands on the hull? James |
Chew my RS
Joined: 05 Oct 05 Location: United Kingdom Online Status: Offline Posts: 790 |
Posted: 12 Apr 06 at 4:38pm |
On a similar theme, I'm on the lookout for an old, wide moth (Magnum 3/Phobia or similar) or a scow moth. There's none on the class site - anyone know of an unwanted one? |
phantom871
Posted: 13 Apr 06 at 9:08am |
l Edited by phantom871 |
