New Posts New Posts RSS Feed: Vago vs..?
Vago vs..?
Fans1024 View Drop Down
Post Options Post Options   Quote Fans1024 Quote  Post ReplyReply Direct Link To This Post Topic: Vago vs..?
    Posted: 09 Aug 07 at 12:19pm
Coming from someone with limited trap experiance, I found the L3000 a far easier boat to trapze from.  I have sailed the L3000 and Vago, both in F4/5 with 128kg all up.  I just found the L3000 a far nicer boat to sail.  Sure, I was crewing, so I can say what its like form a helm on the trap, but nah L3000 is so much nicer than the vago.  BUt that's just me and I am 5'6" so the boom height its not really an issue.
k_kirk View Drop Down
Post Options Post Options   Quote k_kirk Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 07 at 3:59pm
Plastic vs GRP... I don't think this debate will go away any time soon but here's a small tip for what its worth. Plastic is super in any beginner/trainer format with a free standing rig. Bulletproof. Then again any plastic boat with a forestay, shrouds etc you will hear about two problems. Flexing under load & eventual possibility of the forestay, shroud pulling out of the hull. My club has a number of Pico's with the loop on the bow where you clip the jib has been pulled out. Maintenance people tell me this is mostly because of sailors pulling the boat ashore & up the ramp from the jib. Still it comes out if you pull it hard enough. Mounting on GRP can be made more solid.
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 07 at 8:23pm
The good thing about lowish booms is you get more power for less heeling moment - which is what you want on a single hander.  Just look at a Contender, now that IS a low boom!
This is one reason the Vago doesn't work s/h as well as it might.  Also that high freeboard does keep the helm dry and does make the rotomould hull tolerably stiff, but it also makes for quite a climb out onto the wire, whereas on the 3000 you just walk out steadily backwards using the ridges in the cockpit.
As for the class legality of singlehanding a 3000; you already can at most 3000 events and for the rest... I'm working on it.
Javelin 558
Contender 2574
Sumo View Drop Down
Post Options Post Options   Quote Sumo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 07 at 1:58pm
Hi chaps, not posted for a while been a little busy on the work front, however it is nice to see a topic on the Vago with more balanced views for a change.
There is nothing to fear with the construction of the Vago, mine is three years old and been sailed often and hard. The boat is designed with a low rig tension and the side stays attach to solid steel bars that spread the load, so stays pulling out is very unlikely.
Sunseeker View Drop Down
Post Options Post Options   Quote Sunseeker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 07 at 3:16pm
You also need to be completely honest about your own sailing capability, both the RS400 and RS500 are definately not begginers boats even when sailed doublehanded.  In fact all of the boats mentioned have the ability to 'bite' the unsuspecting.
My advice would be to get to your local club and talk to the members, maybe get out with someone and let them see where you are in terms of competence, then be better guided.
If I am speaking out of turn and you are confident with your dinghy competence, my apologies, but better to be safe than ill advised.
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 07 at 8:04pm
I'd concur with that - we've given our pico all kinds of hell and the only thing that pulled loose was a footstrap when yours truly took his fat guts out for a sail in a F7.  Now there's a block of mahogany behind the screws.  And the same happened on my GRP laser 2.
A 3000 with the reefable original (hyde) sails should be OK for anyone with RYA L2.  But yes, a full blown state of the art 3000 can certainly send you for a swim (5 times on Sunday ).
Has anyone tried an RS500 with the smaller "S" rig yet?  All the comments seem to be about the full blown race version.
Javelin 558
Contender 2574
Post Options Post Options   Quote k_kirk Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 07 at 8:44pm
Glad to hear you never saw this. Take a look at the photos I casually snapped last Sunday. I think only 1 out of 8 Picos on the dock that day was still in good condition. I guess folk at my club really abuse these things. Golden rule to follow. Don't use the jib  fitting on the bow to  tie a painter on. They are just not designed for the towing loads...
I am not finding fault in the boat here but rather the sailors and I agree the same can happen on GRP boats as well. The point I'm trying to make is, when it happens and surely it will happen one day, it is much easier to fix things on GRP and end result looks much neater. Looking at all these franken-bows I'm sure you will agree with me.
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 07 at 3:51pm
Yes, but once and the wind dropped fairly shortly after.
But it's certainly easier, I wouldn't agree with the "underpowered"
description I still believe its over canvassed for young light crews.
Sailing it with a very experienced girl helm and me wiring, which gave an
all up weight of 120 kgs, we ran out of control as the wind started to
nudge force four.
A year in now, with me helming and my crew which is all up 155kgs we
can manage a five. If it blows anything more, then out will come the small
main.
Single handed its not as easy as the 3000 and you soon run out of control
if you are as inexperienced as me, at the top end of a three.
The RS400 is easier to sail.
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 07 at 4:08pm
Graeme, most skiffy boats sailed by people who arent completely and utterly confident dont go out in more than force 5 so i think you are doing reasonably well. even if the 500 isnt that much of a skiff. (i certainly wouldnt consider taking out a 600 without some "ballast" in a force 5 (yet))
Edited by mike ellis
Also International 14, 1318
