Main halyard |
Page <1234> |
owain ![]() Posting king ![]() ![]() Joined: 11 Jun 05 Location: United Kingdom Online Status: Offline Posts: 142 |
![]() ![]() ![]() ![]() Posted: 16 Dec 06 at 1:25pm |
Thanks for that garry, i think were going to adjust the block this afternoon. Russ, we shud try and all get to a assymetic event at grafham or sumwhere maybe in april or early summer. |
Owain H
49er GBR055 Fireball 14291 Plymouth Uni Sailing Club & Chelmarsh Sailing Club |
Well arnt there a few TASER events coming up ???
I'm thinking of changing from a wire/rack to a rope/cleat system as I find either the wire or the rope is constantly fraying which annoys me and threatens to break inside the mast just when you don't want it to (ie 15 mins before the first start). If you start with the rope a metre too long you can cut 200mm off every few months to pretty much garantee it wont fail. My first Contender had rope/cleat and I've always wanted to go back to it. If you use 2 cleats in line then they both seems to last ok. But you do need to have them out of line of the turning block so that they don't burn the cams when you're pulling the halyard fast for the first bit of the hoist. |
Laser 203001, Harrier (H+) 36
do u guys mean TASA or TAZER the boat
TWO FRANK-Hunter Impala
Of course you meant TASA or Tasar. Edited by Matt Jackson |
On cats there is a hook at the top of the mast you hook the main onto so that the halyard doesn't take any tension whilst sailing. This is because of the very high cunningham/downhall loads we put on the sails.
Just wondering if any mono's use a similar system? |
errm ive seen a similar system on some 505 where a furel on the wire goes into a catch at the top of the mast the guys with this system took a while to get the knack of it but once they did it seemed really good. means they have a rope halyard and then a really sort bit of wire which is gona strech very little!
same system as used on sonars just in reverse with a lot less wire
Halyard locks have been around for donkeys, the idea being to reduce compression loads on the mast. My spare finn mast has one, but my good one has been modified to an internal halyard with a cleat on the front of the mast.
You all know what i mean TASA, i feel very embarassed now
Page <1234> |
