New Posts New Posts RSS Feed: Moth Gliding
Moth Gliding
jpbuzz591 View Drop Down
Post Options Post Options   Quote jpbuzz591 Quote  Post ReplyReply Direct Link To This Post Topic: Moth Gliding
    Posted: 14 Dec 05 at 9:32pm
yeah i can see what you mean, give me normal water skiis any day of the week, that looks about as exciting as watching paint dry
Jp Indoe
Contender 518
Buzz591
Chew Valley Sailing club
Bristol
Matt Jackson View Drop Down
Post Options Post Options   Quote Matt Jackson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 05 at 8:15am
Originally posted by Matt Jackson
I've seen a bizarre thing with a seat and a foil from underneath but it looked a bit dull compared to proper skiing.
Nope, I stand by my original comment which for accuracy is above. The key bit being COMPARED TO PROPER SKIING. The problem with the foiling garden chair is that (in the video I saw) you couldn't cant it over far enough to go really wide and generate lots of speed.
Laser 203001, Harrier (H+) 36
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 05 at 4:09pm
i want one of them. *ahem* getting back to the original topic: it wouldnt work. moths arent heavy enough to keep momentum for that long and if you had the sails up wouldn't that just be more drag? im not a moth sailor so i wouldnt know but i would have thought no rig would bring the centre of gravity closer to the water making it more stable.
BBSCFaithfull View Drop Down
Post Options Post Options   Quote BBSCFaithfull Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 05 at 3:47pm
What is fun is when you tow a little inflatable rib about 5-6 foot in length. Behind a 5 metre 50 horsepower rib with some one in it. You then get the boat going as fast as possible and gently steer and see the little rib fly like 6 feet in the air . The Fun is when you get to see their faces tee hee
Edited by BBSCFaithfull
Greatfully Sponsored By
www.allgoodfun.com
Int 14 GBR 1503!!
Ian99 View Drop Down
Post Options Post Options   Quote Ian99 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 05 at 10:06pm
Only 6 feet?
"Proper" use of doughnuts and mini bananas behind a 300bhp parascending boat is far more fun
("Proper" means completely ignoring the "Do Not Tow Above 15 mph" warning printed on the inflatable and taking the thing flat out )
Disclaimer - Hitting water at 40+ knots when coming off a wave isn't generally particularly good for your back or neck ......
Edited by Ian99
Philsy View Drop Down
Post Options Post Options   Quote Philsy Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 06 at 3:16pm
Originally posted by Ian99
Only 6 feet?
Why on earth would you want to tow a doughnut at speeds of LESS than
15mph? Have these people no idea of fun?
timnoyce View Drop Down
Post Options Post Options   Quote timnoyce Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 06 at 4:49pm
I am loving that middle photo of the foiling chair... he's got the 'you know it' point going down a treat!
18footer View Drop Down
Post Options Post Options   Quote 18footer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 06 at 4:42pm
I got whip lash when I rudder stalled and through me out the boat foiling at about 16-17knots. Now I can only turn left.
Alex
