New Posts New Posts RSS Feed: Revolutionary Centerboard!!
Boatboy View Drop Down
Post Options Post Options   Quote Boatboy Quote  Post ReplyReply Direct Link To This Post Topic: Revolutionary Centerboard!!
    Posted: 16 May 06 at 9:40pm
 it might be worth it a class with a heavier weight so you get more righting moment from the board. go for it mate!
as the extra mass would be stored in the hull it would'nt make any difference to righting moment.the board in the water would still have the same mass and the same lever so the same righting moment. it would make a difference to the pitching moment of the yacht as their would be more mass lower down in the boat thus lowering the centre of gravity of the boat.but only slightly.
on the subject of building foils you have a multitude of choice depending on the class rules of the boat. personally i would use very high density foam 200kg/m3 plus and uni directional carbon
Isis View Drop Down
Post Options Post Options   Quote Isis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 9:30pm
Originally posted by NickA
Upon which .... has anyone tried making their own foils?  Out of what?
Hold your horses there sonney!! lets not gett too carried away!!! making bits of your OWN boat??
NickA View Drop Down
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 9:26pm
as hyrodynamic as possible I think, ie good airfoil section.
Flat is not necessarily good because you have to transition from leading edge to flat surface to trailing edge again and sudden changes in curve cause the water to accelerate quickly, creating displacement force.
I guess, but don't know for sure, that a really thin board will be good - if you can make it stiff enough not to twist off.
mike ellis View Drop Down
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 9:09pm
does that meen make the board very flat or very nearly normal shape?
Also International 14, 1318
Post Options Post Options   Quote NickA Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 9:06pm
The gospel according to Bethwaite reckons the extra lift will never make up for the extra drag.
Water being so stiff, you hardly need any angle of attack to get lift, and sufficent angle of attack comes from the boat sailing along very slightly diagonally when sailing up wind.
Having said which, I sailed with an aged GP14 sailor once who insisted on heeling the boat to leward when sailing up wind, even in a blow, as the curve in the hull gave him extra pointing - and out point everyone else we did!
So maybe if you make the asymetry subtle enough....
tickel View Drop Down
Post Options Post Options   Quote tickel Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 8:00pm
Thank you all for your interest in this topic. It would be agood idea to not have flat bottom boards as someone suggested and indeed you would only use one board at a time. Downwind stability could be a problem as well since the whole thing would have to be up. How about if you could swivel the board about its axis? or adjustable flaps on the trailing edge? I like the idea of a board which changes shape. You could do that with an eccentric ellipse running down the middle of a hollow soft shelled centere board. Do'nt expect me to do it, we struggle hard enough with our Taser.
tickel
Post Options Post Options   Quote mike ellis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 7:29pm
i know you said clever people only but im going to say something anyway. how would you store the spare board? it would have to be a centreboard boat i thjink. it might be worth it a class with a heavier weight so you get more righting moment from the board. i dont see why it wldnt work if you got a fairly decent shape but that might need alot of trail and error to sort out.
go for it mate!
Blobby View Drop Down
Post Options Post Options   Quote Blobby Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 11:57am
Two proper boards it would have to be - you would never get proper flow around the board if you had a sharp angle at the leading edge.  Would result in loads of drag and drastically reduced lift and be very unforgiving to changes in direction.
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 9:27am
Wouldn't need to be exactly flat on the other side though would they - at least as long as you are never going to have both down simultaneously.
Philsy View Drop Down
Post Options Post Options   Quote Philsy Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 06 at 9:27am
How about a centreboard that changes shape? Some sort of material that will
flip one way and then the other - a bit like a fully battened windsurfer sail.
