advice on 800's |
![]() ![]() ![]() ![]() Posted: 08 Jun 05 at 11:48pm |
98 comes to mind for some reason
carshalton fc ![]() Really should get out more ![]() ![]() Joined: 26 Jan 05 Location: England Online Status: Offline Posts: 2337 |
well ther first nats was in 2000 so must be around that time ish!!
International 14 1503
sailor.jon ![]() Far too distracted from work ![]() Joined: 02 Nov 04 Location: United Kingdom Online Status: Offline Posts: 361 |
when were the first 800's in production? |
yer me and my brother will have to have the racks the full way out so we definatly need the mini racks!! and means we wont fall down the hole!!
IanP ![]() Newbie ![]() Joined: 13 Apr 05 Location: United Kingdom Online Status: Offline Posts: 33 |
Beware If you are a lightweight crew (combined weights less than 138.9 kg) To race legally we will need to have 4 weights PLUS intermediate racks. If the boat you are looking at does not have these then you need to add the costs of buying them to the cost of the boat you are looking at. Secondhand weights & bars are rarer than hens teeth so you are looking at buying new. Costs are 29.95 per weight and bars were 127.66 (plus VAT). Cheaper than a new jib but at least you can choose whether you need one. I was a bit Moral : lightweights look for boats being sold by lightweights (or have deep pockets!) Edited by IanP |
Ian Paterson
800 922 |
brashleyd ![]() Newbie ![]() ![]() Joined: 27 Jan 05 Location: United Kingdom Online Status: Offline Posts: 20 |
Keith ![]() Groupie ![]() ![]() Joined: 22 Mar 04 Location: Scotland Online Status: Offline Posts: 41 |
One structural thing that went on my old boat #876 was the shrowd backing plates were pulled into the hull. They needed beefed up so its something to check that theres no evidence of cracks around the shrowd base plates. Worth checking....
Keith...
I'm no great expert on 800s but I know there was a change from swinging upper spreaders to fixed some time back and also you should thoroughly inspect the mast for corrosion between carbon and stainless and any tendency for the track to come lose. Don't worry about having a twin tiller and part aft sheeting or single tiller and centre sheeting as this isn't going to make the boat perform much different as long as you have strong arms, and you can change it later when you've got enough control to go racing. Also sails are an expensive item and as beginners to high perfomance sailing you are going to trash a gennaker and very likely a main. Its also quite easy to snap the tip off your dagger board too. Helming from the trapeze usually goes through a few tiller extensions at first so keep the fancy carbon one at home and buy some cheap plastic tube to use until you stop falling out the back. As for hulls I reckon scrapes at the transom are a sure sign of poor care and any damage is likely to be more expensive to repair than lesser boats since I think the boat uses epoxy resins. Good luck - you'll need it if you aren't experienced at trapezing lesser boats.
its a really strong rope, stronger than the equivalent diameter of steel wire, also very expensive, but make sure that with this, that its been spliced and not knotted, also check all the deck fixings to see if they are loose as this can alow water into the hull in all RS's and makes them heavier as the construction method on them means they absorb water very very well if given the chance
thanks!! i will bare that in mind when looking at boats!!
