Rope Self Tackers |
![]() ![]() ![]() ![]() Posted: 30 Aug 07 at 2:55pm |
Want a self tacker on the 14 but dont want the hassle of cutting sails too much and putting a bar in etc.
Help would be appreciated Cheers, Alex |
Greatfully Sponsored By
Id definantly recomend doing it with a track properly... It took me just a couple of days to do mine in between other jobs and was dead simple despite my silly shaped deck...
Ive yet to see a rope system that looks like it would give enough control. If your jibs are overlapping and you dont want to cut them down you could always go for a W track? |
Franco ![]() Groupie ![]() Joined: 15 Jan 07 Location: United Kingdom Online Status: Offline Posts: 40 |
Buy the 14 parked oposite you last week at POW week!
Never seen one that was any good at all - unless of course you want to be dog slow upwind... IIWY I'd bite the bullet and get the track.
spin cycle ![]() Groupie ![]() ![]() Joined: 06 Oct 06 Location: Scotland Online Status: Offline Posts: 43 |
I fitted a 49er jib track to my 14 and it worked fine. Only problem was I could not retract the pole fully for travelling. The morrision10/11 jib also fitted fine on this set up Gav H
Told you alex but would you listen ... er no |
RS600 988
Right will get a w track i feel. jus the thought of putting holes in my deck wasnt appealing.
Cheers, Alex |
One of the 3000 class has been experimenting with self tackers to go with the big and roachy, overlapping North jibs. A W track was tried but the sail didn't reliably cross the boat. The continuous curve Mk2 track is reportedly much better. The too-far-forward jib cleat that results from the continuous curve is compensated by use of a clew board on the jib. Ie it's sheeted from slightly in front of the clew with the board providing tension in the roach. I have yet to see it in use mind .
Javelin 558
Contender 2574 |
What is a W track?
A W track is one where there is a reverse curve in the centre rather than being a continuous radius. The sheet gos slack as it goes past the reverse curve. It enables the track to be a bit further aft.
