Rs feva daggerboard |
themeaningoflife ![]() Far too distracted from work ![]() ![]() Joined: 06 May 11 Location: Essex/ Kent Online Status: Offline Posts: 212 |
![]() ![]() ![]() ![]() Posted: 07 Nov 12 at 11:15am |
I think if you contact RS they now can supply some closed cell foam moulded to the cavity that is a fairly instant fix for the problem.
Macwylie ![]() Newbie ![]() Joined: 05 Nov 12 Online Status: Offline Posts: 2 |
Richard & Moppo, thanks for your advice. I'll post back when I've got a solution!
Macwylie
Edited by Macwylie - 06 Nov 12 at 5:58am |
Moppo ![]() Newbie ![]() Joined: 11 Nov 08 Location: United Kingdom Online Status: Offline Posts: 30 |
Contact RS before you do anything with it. It may need to be reftrofitted with more foam before sealing up (the maintenance guy at the Feva Worlds in 2011 spent 3 days doing just that, solidly).
B14 694
I would email RS sailing, take some pics too. The Ali centreboards are newish, you may have a faulty one.
My rs feva aluminum daggerboard fills with water. Probably good for ballast, but I read that they're supposed to float! Any suggestions for sealing the end? Silicon?
Thanks, Macwylie
