Fruit based boat for the ladies? |
EuropeGBR395 ![]() Newbie ![]() Joined: 30 Oct 12 Online Status: Offline Posts: 9 |
![]() ![]() ![]() ![]() Posted: 05 Nov 12 at 8:14pm |
The Europe is definitely a steep learning curve! I have often been told that they are easy to sail, very hard to sail well.
Never sailed a Streaker personally but they do look like nice boats and they are absolute handicap bandits!
robin34024 ![]() Posting king ![]() ![]() Joined: 03 Jan 12 Location: Lincoln Online Status: Offline Posts: 116 |
personally, i would reccomend the streaker, its well balanced, spacious, and quite forgiving, however, i am a bit biased. i would say that from my experience, the europe is very twitchy and might be a bit of a struggle learning in one. i would say just try anything you can borrow and make a judgement from what you have sailed.
I am probably a bit biased... but the Europe is a lovely little boat. I am 6ft (and a girl) and weigh about 63kg and it suits me wonderfully.
In light winds the cockpit is a little cramped, but the fun you have when the wind picks up makes those moments of being crouched down in a gap near the front kinda irrelevant. It sails differently to most singlehanders too. You sail very loose and there is no weather helm at all. I adore mine, if you're anywhere near Llandegfedd Reservoir in South Wales you're more than welcome to have a go in mine :)
NickM ![]() Far too distracted from work ![]() Joined: 27 May 09 Location: United Kingdom Online Status: Offline Posts: 328 |
The streaker is the most comfortable for that height and is a lovely boat. Otherwise yes the lightning is also a good choice.+1
A europe is ok if you're a flexible 5'10" (I am 5'11") better in fact than a byte or a splash or anything along those lines because in light winds the cockpit is quite cramped (her indoors has a byte). The streaker is the most comfortable for that height and is a lovely boat. Otherwise yes the lightning is also a good choice.
The Quba is the new Pico isn't it? Could be worth a look.
Your hurricane or short tiller and single wire the 800
Musto Skiff and Solo sailor
Depends if you want Plastic or GRP, the Topaz, Feva, Q'ba fill the plastic section, otherwise as said the Byte is cheap (with original sail) or you have the Comet
or a Flash / Splash ( Flash = Splash with a bigger rig ) depending on her weight of course
Take a good look at a Byte...
