New Posts New Posts RSS Feed: Sail eyelet replacement
Owenfackrell View Drop Down
Post Options Post Options   Quote Owenfackrell Quote  Post ReplyReply Direct Link To This Post Topic: Sail eyelet replacement
    Posted: 03 Jan 12 at 10:24am
The battern pocket eyelets on my Dart main sail are made from aluminium and have reacted with the salt and are now starting to crumble. I therefore want to replace them before the battern tension rips the sail.
First off is this fairly easy to do or would you only trust it to a sail loft and secondly would you go for brass eyelets as a replacement. The sails are not near new but do have plenty of life left in them for my use as i don't go racing.
Cheers
Max McCarthy View Drop Down
Post Options Post Options   Quote Max McCarthy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 11:21am
I would get a sailmaker to do it, I wouldn't want to risk damaging a sail for it.
Vintage skol moth 3438
jeffers View Drop Down
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 11:33am
For what most sail makers (or boat cover makers) will charge you to replace them I would let them do it. Much less hassle and you know it will be done well.
Mister Nick View Drop Down
Post Options Post Options   Quote Mister Nick Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 11:50am
Take it to a decent sailmakers and ask them to do it. Much less hassle and they'll make good job of it. Plus, if it goes wrong then you can blame them and not you! ;)
radixon View Drop Down
Post Options Post Options   Quote radixon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 6:09pm
Next question I'd be asking is, I live in XXX where would you recommend.
Post Options Post Options   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 6:56pm
The eyelets tend to be nickel plated and yes as you've noticed, they corrode.  Sadly the brass ones won't actually fair you much better.  They just corrode in a slightly different colour.
If you were to do it you would need both the closing tools, which aren't cheap.  Better off just taking it to your nearest sail maker.
Where abouts are you?
Doug H
Post Options Post Options   Quote Owenfackrell Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 6:59pm
Thanks for all the replies. I live in Blackfield just outside of Southampton so any recommendations welcome.
ASok View Drop Down
Post Options Post Options   Quote ASok Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 12 at 8:04pm
Go and see Grant Pigot. Cat sailor and local (Weston). Always done a good job for me and well priced.
Stuart O View Drop Down
Post Options Post Options   Quote Stuart O Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 12 at 8:12pm
+1 for Grant Piggott at GP Sails in Warsash www.gpsails.com
Post Options Post Options   Quote Owenfackrell Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 12 at 9:03am
I would like to say that i got Grant Piggot to do it and he laso carried out some repaiers to the sail its self all for a very resonable price. So a big thumbs up from me.
