Hull repair/ spray job |
fudheid
Joined: 21 Apr 11 Location: 51.53 N 01.28 E Online Status: Offline Posts: 241 |
Topic: Hull repair/ spray jobPosted: 14 Dec 11 at 11:13am |
Does any one know what is the best paint to use for touching up a repair? have an area about 12" x 12" (30cm x30cm to those under 30) been told halfords fibreglass primer but then what?
Or is there something better?
Cheers you
only me from over the sea...... |
Ruscoe
Joined: 12 Jan 10 Online Status: Offline Posts: 1514 |
Posted: 14 Dec 11 at 11:40am |
I guess it depends what and where you are painting. I always use halford white primer on foils prior to wet and dry and fairing, gives a great long lasting finish. Its cheap and dries quickly so you can add multiple layers quickly. Also with it being a primer the finish comes out relatively even unlike a gloss paint.
fudheid
Posted: 14 Dec 11 at 1:25pm |
Its a patch on the topsides does that make any difference?
Cheers you
Ruscoe
Posted: 14 Dec 11 at 1:34pm |
Depends if its completely submerged in water constantly i suppose, but given this is posted in the dinghy section i guess your right it probably doesn't matter. Halfords Glass primer is usually top coated with their car spray paints, which would be fine on a dinghy but they don't flex as well as marine paints. Automotive sprays will have an additive in the paint on the plastic wing and bumper pannels to allow for more pannel flex. What are you painting over, i doubt very much you will get any kind of colour match from a spray can, even white has thousands of different shades therefore is there any real point in spraying over the repair at all, as it would still be visable? |
Posted: 14 Dec 11 at 1:57pm |
Really you should be using the same paint system again. You can get strange effects if you mix paint systems...
fudheid
Posted: 14 Dec 11 at 2:18pm |
Thanks for replies, its an epoxy patch i want to paint it to hide it up a bit better, i'm gonna progrip over it as well - i can't replicate the nonstick finish??
Cheers you
Ruscoe
Posted: 14 Dec 11 at 2:36pm |
If you are going to stick progrip over it a Halfords Fibre glass primer will be fine, i doubt very much if you would get any kind of reaction.
Posted: 14 Dec 11 at 2:44pm |
It depends what you paint it with next time the whole job is done. Two pot paints especially are very aggressive, and it spoils your day rather thoroughly if traces from a patch bubble up and ruin the job. |
