Stepping on from a Laser 3000 |
james07 ![]() Newbie ![]() Joined: 20 May 11 Location: United Kingdom Online Status: Offline Posts: 3 |
![]() ![]() ![]() ![]() Posted: 20 May 11 at 12:01pm |
I'm looking to step on from a laser 3000 into something lighter and quicker. Would the RS 500 be a suitable boat? I'm not sure of my ability to helm on the wire so to me this seems a logical path to take... Do any of you have any thoughts?
The RS500 is a nice boat, but it is more an alternative to the 3000 than a step up, I'd have thought. Carries a little more weight and is a bit faster, but possibly heavier, too. The only "step up" in performance I can think of is the 29er, really, or learn to helm from the wire. I've done a (very) tiny bit, and it was fun - must do more one day.
Obviously there's the 4000. Good value for money at the moment. Quicker but probably doesn't tick the 'lighter' box.
Jaws ![]() Groupie ![]() Joined: 27 Nov 10 Online Status: Offline Posts: 92 |
I haven't sailed a 3000, but I would expect it's harder than a vago to sail. I found the difference between 500 and vago to be fairly small, with the 500 just needing slightly faster reactions and slightly cleaner maneuvers, so there can't be masses of difference with the 300. The 29er is simply not on the same level as those, it's much twitchier and punishes errors much more ruthlessly. Once you get the hang of it (about 6 sails for me) it's great fun, until then you wonder why on Earth you're sailing the thing. I'd say the 29er is a good step up; it's a lovely boat to sail, and a nice challenge to learn.
Edited by Jaws - 20 May 11 at 12:41pm |
RS600 794
Thanks guys, really useful. I've heard the 29er doesnt suit those heavier crews? My crew and I are around the 80 and 90 kg mark respectively...
Is your crew wedded to the trapeze? I'd suggest a b14 (but then, hey, I would). No need to learn to steer from the wire!.
Bascially, at that weight you're looking at "grown up" boats- as far as assymetrics go you've got the B14, I14, Laser 4000 (no longer built), Iso (ditto), RS800, 49er as reaslisitic choices. RS500/29er are for smaller people really.
For helming for the wire, the 800 is a good choice- it's a pretty stable platform, designed to be "easy" to sail.
Al |
Looks like I'm going to have to man-up and learn to helm from the wire...!!
No you're not- go B14!
Al |
We 'stepped up' from an L3K to an Rs500. Our instant feel was that it was more tippy, it was more difficult to handle in a blow, it was over powered above force five, but obviously much faster in medium to light winds.
Good things were it had a centre board (which you have to fiddle with to stop falling down at the pivot)the rig bits were all Selden and worked very well and is a good sea boat, doesn't nose dive, is very good in light conditions unlike the 3k, but doesn't exactly 'plane' upwind in the same way the 3 k did when it was very breezey. (Could be because we were always over powered so tended to stuff it rather than sail free). The Alto we currently sail is a hell of a lot nicer friendlier boat.
Ok, that's way too heavy for a 29er. I might suggest the 800, it's a good one to learn to helm on the wire; I only had a quick spin in one in a force 3, but it definitely isn't as tippy as the 29er. I Haven't sailed any other twin trap boats, so that's all I can say on them.
RS600 794
