Techy help- GPS |
![]() ![]() ![]() ![]() Posted: 08 Apr 11 at 11:27am |
so, in a bonus powered shopping git I bought myslef one of these Oregoon Scientific ATC9K with a GPS module. I've been trying it out on my bike commuting this week, and I'll attach it to the boat this weekend. Picture quality seems good. In the software, the GPS mapping is good.
There's a "but" though. The GPS files seem to be in a proprietry format. I'd like to be able to use a site such as mapmytracks.com, but the .map file format is not recognised, and opening the files in notepad just gives gobbledygook, not a nice set of comma seperated values.
Anyone clever enough to be able to help? I've tried all sorts of google searches and not got anywhere.
If it would help, I can send the technically gifted an example file after work- PM me an email address.
It's a shame, it's a nice little unit, if only they hadn't been boneheaded with their file format.
Al |
Looking at the link it says that the GPS files will go into google earth so they're probably in KML format (or KMZ which is KML zipped).
mapmytracks wants GPX files. So it would seem that a file converter is needed.
Just done a quick google and there are some free ones available, I don't know what they're like though.
Dunno if that helps Edited by GK.LaserII - 08 Apr 11 at 1:42pm |
Cheers- they definitely have the unhelpful extension .map, though they may be a renamed kml/kmz, I'll try renaming one and see if that sheds any light.
Al |
.map files are associated with maps not tracklogs or so I thought....sounds a bit odd. The Oregon link def says the tracks are openable in google earth /google maps. Give it a go, if they do open in google you should then be able to save them as KMZ or KML. Edit;It's a right pain when they use "inovative" ideas with the file types, just had a similar problem with a waterproof video camera.
Just edited my above post it should of said GPX files for mapmytracks Edited by GK.LaserII - 08 Apr 11 at 1:44pm |
