Buoyancy tank foam, |
Ruscoe
Joined: 12 Jan 10 Online Status: Offline Posts: 1514 |
Topic: Buoyancy tank foam,Posted: 02 Apr 11 at 10:06pm |
Hi,
I am in the process of restoring/modifying a 70's Super Graduate, to sail with the little one. The Buoyancy tanks were filled with a foam which over the years has taken on some water. As per the class rules the foam need to be attached to the boa, although the years have meant this has now detached. I have removed all the old foam, but now need to replace it with something more modern that will not absorb water. Can anyone make some recommendations as to the best foam to use, and where to get it? Many thanks, Russ Edited by Ruscoe - 02 Apr 11 at 10:09pm |
winging it
Posted: 03 Apr 11 at 10:23am |
people use all sorts of stuff - polystyrene cut off, old buoyancy bags, sealed up milk containers. My choice would be the polystyrene balls used to go in bean bags tied or taped up in very sturdy plastic bags. That way you can push them into all sorts of nooks and crannies. If you try to get 'the real thing' you will pay a lot more for the same effect.
For even more esoteric and expert answers you really need to cross into cvrda territory... http://www.cvrda.org/community/ this is very much our sort of question! cheers, Nessa ps webmuppet recently undertook just such a project for his littl'un, with great success! |
winging it
Posted: 03 Apr 11 at 10:24am |
ps, if you still have those jibs I have a ToY now too which I reckon is crying out for a jib
Ruscoe
Posted: 03 Apr 11 at 10:45am |
Nessa i am really sorry i had completely forgotten to pack them up and post them to you. I still have them and they are yours, i just got to remember to pack them up and send them. This weekend has been the first i have had time to breath for a while so if you send me a PM/E-mail tonight i will pack them up and get the wife to take them to the post office this week.
As for foam, the Graduate rules say it needs to be permanently attached to the boat, so polystyrene balls are out i think. As are air bags (which was my choice, until i read the rules)
Contender 541
Posted: 03 Apr 11 at 3:26pm |
Russ, this sounds like an obvious question but, have you asked the Graduate class what they do?
Crew on 505 8780 |
JohnW
Joined: 17 Jul 07 Location: United Kingdom Online Status: Offline Posts: 552 |
Posted: 03 Apr 11 at 3:27pm |
How about swim noodles? You should be able to strap them down to the hull inside the tanks.
I dont know how many you would need and if they would be cost effective. |
Ruscoe
Posted: 03 Apr 11 at 5:58pm |
Its not a common thing as i understand it. The graduate forum is really inactive as well. i like the swimming noodle idea, anyone know what they are made of? if i caould buy that foam in larger blocks it would be great.
Contender 541
Posted: 03 Apr 11 at 6:07pm |
Russ
I think they are made of expanded PP.
If they are then it is a common material in packaging.
I rather suspect you have some contacts in that are you can tap up, but if not let me know and I can give you a few names.
BTW - You going to Burton nex week?
Crew on 505 8780 |
Webmuppet
Joined: 11 Mar 06 Location: Suffolk Online Status: Offline Posts: 534 |
Posted: 03 Apr 11 at 6:17pm |
Russ
I peered into the tanks of our Supergrad and there's nothing in there. Perhaps I'm being dim, but why do you have to have foam etc. in the void - surely it's just a case of making sure that the tanks are watertight ? Cheers, Nigel
Graduate 2530 'Galaxy' |
Ruscoe
Posted: 03 Apr 11 at 6:59pm |
Stuart, Yeah we will be at Burton next weekend, had a really good sail today. Tim Rush is dropping off our new kite and hopefully new carbon poles and Twin Spinno...
![]() Nigel, The rules state that GRP boats have to have foam secured in the tank, the supergrads only have one tank and no bulkheads so i guess its in case you are holed. i have removed all of the foam from ours as it was full of water and no longer attached. Taking all of the foam out, the rear traveller moulding and a few other bits has saved me about 6kg in weight at present!!! So of this will go back on when i rebuild the deck/hull, fill her with closed cell foam (just in case) and then paint her. Wish i had weighed her at before i started.
Edited by Ruscoe - 03 Apr 11 at 7:03pm |
