New Posts New Posts RSS Feed: pro grip
pro grip
tim grasse View Drop Down
Post Options Post Options   Quote tim grasse Quote  Post ReplyReply Direct Link To This Post Topic: pro grip
    Posted: 07 Nov 10 at 6:42pm
Hi.
My pro-grip on my boat is starting to look tacky and i have bought some replacement pro-grip, but it has no adhesive side. would No more nails adhesive work well or should I use evostick for securing the Pro grip? and also how would you take the old stuff off in 1 piece so I can use some if the pieces which are still intact?
thanks
Tim
s.a.l.t.y View Drop Down
Post Options Post Options   Quote s.a.l.t.y Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 10 at 6:51pm
Evostik would be your best option. But buy the spray can version http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9254422&fh_location=//catalog01/en_GB/categories%3C{9372013}/categories%3C{9372031}/categories%3C{9372100}/specificationsProductType=adhesives&ecamp=cse_go&CAWELAID=266887314
It will save you all the time and hassle of pasting it on twice. Just mask up the area of the boat and pro grip and then spray away!
Post Options Post Options   Quote tim grasse Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 10 at 6:58pm
thanks. my boat has a rough pattern on the deck, probably designed for grip but it doesn't help at all, would the spray work with the pattern on the deck?
thanks
tim
Post Options Post Options   Quote s.a.l.t.y Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 10 at 7:26pm
Yeah it should do as long as you do a thickish coating so theres maximum contact between the 2 glued bits of evostik.
PeterG View Drop Down
Post Options Post Options   Quote PeterG Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 10 at 8:39pm
The stuff I was recommended, and has worked fairly well is Alpha Thixofix, e.g. here:
http://www.isaaclord.co.uk/productDetail.aspx?product=792&subCat=44&parentCat=6/44
I don't think you can get a spray
Peter
Ex Cont 707
Ex Laser 189635
DY 59
winging it View Drop Down
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 10 at 9:34pm
I have used thixofix, but also found wickes contact adhesive to be pretty good.
Post Options Post Options   Quote tim grasse Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 10 at 10:11pm
thanks for all the suggestions on glue but do you know how to take off the old stuff without it ripping so there is less work on preparing the deck?
tim
Post Options Post Options   Quote winging it Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 10 at 8:30am
If you take off the old stuff without tearing it then the glue will either be on the old pro grip, meaning it's uselss, or it will be one the deck, so you'll end up having to scrape it off.  It's a n win situation.  I think Gil Woolley posted a solution in the yahoo forum which so it might be worth looking there, or sending him a message.
Villan View Drop Down
Post Options Post Options   Quote Villan Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 10 at 5:43pm
Heat gun! Warm the progrip up and peel it off slowly .. it'll be stretchy but should melt some of the glue off with it.
TandyUK Servers
Olly4088 View Drop Down
Post Options Post Options   Quote Olly4088 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 10 at 7:05am
I agree with Villan when we did the 5oh we heated it slightly and it came off fairly easily. Once you have applied it it might be worth running some kind of sealent around the edges to keep it from lifting when move around the boat
Phantom 1298
