laser gel mix |
![]() ![]() ![]() ![]() Posted: 22 Sep 10 at 7:38pm |
It is blue gee. her next door is a vet, I'm off round to borrow a syringe...
didlydon ![]() Far too distracted from work ![]() ![]() Joined: 15 Oct 08 Location: Margate England Online Status: Offline Posts: 280 |
Yep, 2% is right if it's a Blue Gee product. If you can get hold of a tiny syringe, that'll measure it. A good way to visulise quantity of gelcoat resin is a teaspoon is 5ml, so work from there depending on quantity required.
Vareo 365
If you add too much catalyst you get a fast cure but it doesn't set as hard - you sort of end up with a rubbery finish...I was always told to err slightly on the not quite enough and give the mix longer to cure
2% is the reccomended. However that is always difficult to tell (how do you measure it) so I tend to use extra catalyst to make sure it goes off. Bigger is better right?
Landlocked in Africa
My gel and catalyst arrived from laser performance today but without any indication of the mix ratio that should be used. There is 500ml of gel, but a teeny tiny bottle of catalyst. Does anyone know what the mix ratio should be and how it is best achieved?
I normally use pp gel, but this time wanted the right colour match. |
