How fast is a graduate? |
Page 123 10> |
MattHarris ![]() Groupie ![]() ![]() Joined: 03 Oct 06 Location: United Kingdom Online Status: Offline Posts: 94 |
![]() ![]() ![]() ![]() Posted: 03 Sep 10 at 11:29pm |
We have a pair of Graduates at our club and between them they have won everything this year, normally by at least 2-3 mins ahead of the next boat. Both have the new style sail plans and race of 1165. Having calculated a new local PY using the pys website it has come back as being 1110. As predicatable they are less than happy about this and claim that at the grad agm they all think the handicap is fair (funnily enough). Does anyone else race against the new style grads and whats your experience of this? If i can get more information i can start to build a case for either the data being wrong or (more likely) a change of handicap. Thanks in advance. |
A well sailed boat that has been updated within class rules that suits the water it is sailed on well usually sail to below it`s PY. As An example I am usually beaten over the line & on PY by a solo while sailing my Phantom but the sailor concerned is very good,his boat is well prepared & is ideally suited for his weight & the water it is sailed on. So are the grads sailing below their PY due to new sails OR have they just upgraded their sails from old rags which were slow in the same way that you would if your sails were shot? & thereby gained the 30 - 60 PY points that new sails usually bring. Were they last placers last year? or top end of results but not winning? In my opinion,it sounds like you would like us to build a case for personal Handicaping for you. sorry but thats how it smells to me! |
Phantom 1181
Both boats are new to the club and so we have little information to go on, which is part of the problem. The helm of one sailed a radial for a few months last year and although far from a bad helm wasn't really winning any races. As for the personal handicapping thats exactly what i'm trying to avoid, i know the second helm is good but i'm unsure how good exactly. Hence why i'm after more information on whether other clubs are having similar problems with their grads or whether we've just got two good helms in well sorted boats. One argument that comes back is how can a boat with less weight and slightly more canvass that an enterprise be 50 points slower? I know that the hull length is around 1 1/2 feet shorter and maybe this is the 50 points? Alternatively adding a fat head sail and more sail area must surely make a boat quicker than the 2 point (7 sec/hour) change that was made to the handicap last year? Maybe not i don't know, hence the question...anyone got any ideas? |
Why not try and borrow one of the graduates for a series and race against the other one, invite him to do the same with your class and you will get a more accurate idea of his skill level. Im very much generalising here but almost all development boats will be quicker than earlier boats within the same class - otherwise its not development! The handicap just allows those with older boats to still remain relatively competative. If you are going to have personal handicaps, it needs to be done for everyone. I personally think its a great thing, you could easily run it using the same results for the other series. At the end of the series you award a small trophy. It means almost nothing but if you win a trophy it means you sailed well or are improving, a real entheuasm builder for newcomers to the sport I would have thought. |
Landlocked in Africa
Easily... Sail area counts for very little compared to hull length. We have one of these and there's no doubt at times he's horrendously quick, but on the other hand he's pretty damn quick in a Solo too... |
tickler ![]() Really should get out more ![]() Joined: 03 Jun 07 Location: Tunstead Milton Online Status: Offline Posts: 895 |
I believe that the new Graduate rig does more than give add sail area, I think it alters the balance of the boat and makes it point better. We have sailed against one, an old boat with new sails, and it did seem inordinately quick given its short length.
I get the impression that although there are many grads that may race, most are a single grad at a club (i know of two other clubs where this is the case) and so its impossible to do a handicap adjustment thats not a personal handicap. And as has been discussed in other threads i'm not out to handicap the sailor just to ensure that the handicap is as fair a representation of the boat as possible. |
As a long time fan of the Grad and occasional owner I can
confirm that in the right conditions they sail well below there handicap... however in open water when the wind is say F3 and above they struggle... so as an overall I believe the handicap is fair. However if your sailing inland in predominantly light winds you may need to make an adjustment to arrive at a fair number. I believe Chipstead rate them at around 1140 ish. As for pointing... the Grad has always been a demon upwind, the new sail plane hasn't really changed this... although it has probably made it easier to get the best from the boat. (with the old rig you had the rake the board well forward to get the balance right but with the new rig, with more roach, this isn't so critical) Ian ex Grad 2965, 2870 |
RS300
See 1140 is something i could very well believe to be a more realistic number for the conditions, also it may be easier to convice all parties if another club is using this number. Are other Grad clubs using alternative numbers or is this a one off? |
What is the water like? Can't help but see you sail a B14. I can't think of many places which would be good for both B14 and Grad in the same weather conditions!
Page 123 10> |
