Starboard boat capsizing onto port boat |
![]() ![]() ![]() ![]() Posted: 20 Apr 11 at 1:27pm |
The stbd boat is not capsized until the masthead hits the water, but remains right of way the whole time.
You had time and opportunity to tack or bear earlier off to keep a sensible distance from the right of way boat.
There are very few excuses for collisions. One or both boats is always in the wrong.
Sorry, that's not always the case. If you are the keep clear boat, it all depends on whether or not there was a change of course by the ROW boat (assuming the capsize wasn't deliberate). See above. |
Only IF there was a change of course... if S (right of way boat) loses control (accidentally) and heels to leeward (or windward) WITHOUT changing course [contact] then P (keep clear boat) 'unfortunately' has failed to give room. If S changed course (quite possible) in the process of losing control, only then can P be exonerated and S has failed to give 'time and opportunity'. Just one of those things we all have to face when racing in close proximity in gusty 30 knots. |
If a boat capsizes n you then I believe you will always be exonerated (unless they had been over for some time and you ploughed in to them).
A Seabadger ![]() Far too distracted from work ![]() ![]() Joined: 11 Oct 05 Location: United Kingdom Online Status: Offline Posts: 222 |
Isn't it a case of having "time and opportunity" to keep clear. As you didn't have either despite your best efforts you are not in the wrong.
I don't suffer from insanity...I enjoy every moment of it.
Agree, if S changed course in the act of capsizing then P should be exonerated. If however S capsized whilst maintaining its course (and it wasn't a deliberate act) then unfortunately P has failed to keep clear. The extract below to a Q&A in RYA casenotes 1988/8 illustrates this point. Although it refers to a windward/Leeward and a heel to windward (ie in a lull), rather than Port/Starboard and a heel (capsize) to leeward in a gust. I believe the same principle applies; QUESTION 1 Two boats are close-hauled on the same tack. L, without altering course, heels to windward so that her masthead touches W’s mast or sail. Is it fair sailing? ANSWER 1 If carried out deliberately and with the intention of making W break a rule, it would break rule 2, and W will be exonerated for breaking rule 11 under 64.1(c), provided that she was previously keeping clear, as defined. But if the contact is caused by, for instance, wave motion or a wind shadow, L breaks no rule, and W has not kept clear. EDIT; footnote; S was in the act of 'heeling to leeward' when 'masts clashed' (contact) and at that moment in time wasn't actually capsized. S could argue that the mast contact prevented recovery from the heel to leeward and resulted in the capsize. Edited by Andymac |
found this on a RYA pdf. "Rule 16 applies to a right-of-way boat that alters course out of control. When a boat has capsized near another,obligations under the rules of Section A of Part 2 end,and are replaced with an obligation to avoid thecapsized boat, if possible. A boat is not to be penalized when she is unable to avoid a capsized boat." |
I agree with Al. Morally you did all you could and do not deserve to be penalised. From a strict rules point of view, it depends whether S did or did not change course. If S changed course, and you did not have room to keep clear, then S broke rule 16, and you deserve to be exonerated for breaking rule 10. I have difficulty visualising how, with P dipping S, S could have capsized so as to contact P without changing course. There was contact. Rule 14 comes into play. If S tipped into you so fast that you could not avoid her, then it was not reasonably possible for you to avoid contact. Just possibly you could win a protest under rule 14 saying that it was possible for S to avoid contact with you by maintaining control, however that would require injury or damage, otherwise S can not be penalised under rule 14(b). |
laserblue ![]() Newbie ![]() Joined: 04 May 07 Location: United Kingdom Online Status: Offline Posts: 2 |
Opps!. Quite right I was on port and I could not cross ahead of the starboard boat.
Take it the first line (because you've typed port twice!) that the other boat was on starboard? I think by bearing off enough to pass his transom you've done all you can- you cannot predict a boat capsizing, and should not have to anticipate the other boat doing something stupid/unfortunate.
Al |
