Winder rudder stocks |
Page 123> |
![]() ![]() ![]() ![]() Posted: 29 Jun 10 at 9:15pm |
Old broken Winder stock is now on ebay folks!! http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300 441988178&ssPageName=STRK:MESELX:IT
If that don't work its item number: 300441988178 |
I was talking about lifting rudders in general. My RS blades needed the pivbolt holes filling and redrilling. No problem with this as its a maintance issue, but a pain all the same. With a dagger rudder you can pull it up a bit at a time and still not have a loaded rudder (like you do when you partially lift a lifting version) the running into the beach scenario isn't such a problem in a phantom as you have a board up and down control and the boat is slower and more stable then a musto so you have more time! My Milanese blade is very light for a wooden sheathed blade, but not as light (i suspect) as a full carbon job) As mentioned before, if i had the choice/time again i would buy the dagger style over the traditional lifting every time. But different strokes for different folks i guess! |
For sure, your Milanes blade will be heavy, but from my memory I don't think the Winder stock/blade combo is at all heavy. Having watched our resident MPS sailor crashing into the beach on many an occasion, I reckon that getting both a dagger board and dagger rudder up late enough is a bit tricky! Just getting to the blade and pulling it up in time seems to be a challenge, esp. if it's tight enough not to rattle in the stock. You can uncleat a pivoting rudder well in advance and it just pops up undamaged when it needs to (the Winder blade seemed to handily stick just a little when right down). Never had any problems with my Winder rudder not being fully down except when I broke the downhaul rope on a rock, but that would probably have meant a broken blade or transom with a dagger. I've never needed to fill and redrill any blade. What are you doing with it?! |
Medway, i would think it is a fair bit lighter then the
Milanes blade and carbon winder stock. I will weight it with he blade in o see the difference. Also if i hit a rock won't my centre board be the main issue??? I actually think that dagger rudders are easier to use, no grief with the downhaul uncleating, or having to push a lock pin through, you know the blade is all the way down, no need to refill and drill the pivot hole once every couple of years, no worry of anything getting caught between the stock and blade locking the rudder half up and half down! they are simple light and effective. |
That looks like a dagger rudder. No thanks! I can't believe the pivoting Winder is any heavier, so why would you pay a higher price and have considerably more inconvenience/breakability if you hit a rock? |
Ha, Jimbo when i had my 300 rudder and stock stolen it wasn't that simple pal. They were out of stock and it took 2 weeks (at least) if i remember!! The lead time was crap, The winder stock has got to be one of the most popular stocks on the market (hasn't it) I think in hindsight i should of sold my milanes blade and bought on of these!! http://www.maguireboats.com/default.asp?m=dp&id=76824 But i hadn't seen them before i ordered my new stock. |
I agree RS are very good with their warranty stuff when it involves a component they can send you but you wont be quite so happy if you have a hull issue….. When I had a split in an RS hull due to poor manufacture I ended up having to tow the boat back to them, leave it there 2 weeks and then go back again to collect it, a total of 400 miles driven on my own time and expense for a warranty issue. I then had to repeat that 2 further times due to the repairs not working! A total of 1200 miles! |
Stick it on ebay with some pictures and dimensions and let us all know? I suspect someone who needs one quickly will pay a bit more than someone like me who intends to put it aside until a blade comes along/gets made! Hard to guess a value but if I buy something on ebay, theres always the idea that you can re-sell it for the next lowest bid if it doesn't work out... There is an interesting article on the N12 website showing how to make one. I fancy having a go, but don't have the time right now. |
Chris its now empty.
I may put the stock on E-may as i seem to have an inbox full of reponses about the stock, it seems fair on everyone that way, but PM me your offers highest bid secures |
Watch this carefully. Depends on the aluminium, but I've just had to repair some carbon poles seriously damaged by an ali sleeve corroding. And the boat was sailed on fresh water. Yo MerlinBoy, your PM box is full and I might be interested in the broken stock!!!! Cheers, Chris
Page 123> |
